A better Merc mechanical fuel pump (seawater pump mounted)? >
Old 08-01-2008 | 03:21 PM
BillR's Avatar
OSO Moderator
Default A better Merc mechanical fuel pump (seawater pump mounted)?
Like alot of motors my 575SCi's have the lousy mechanical fuel pump mounted on the seawater pump. Like 99% of them, mine are leaking fuel into the oil reservoir and tearing out the seals on the sea water pump.
That said: the 525's also have the same fuel pump design. However if you look at Merc parts, the NEWER 525's (#OM956327 and up) have a new part # for the fuel pump (#889275T) but the same parts #'s for sea water pump.
Did Merc get smart and upgrade that POS fuel pump???
BTW: The part # for the old fuel pump is 842429a01
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-04-2008 | 07:41 AM
BillR's Avatar
OSO Moderator
Bueller? . . . Bueller?
Lots have complained about these pumps leaking. Is it possible Merc has a better design and no-one knows about it???
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-04-2008 | 09:35 PM
ACTIVESHACK's Avatar
When I had to change both of mine last year the new ones were different. I'm going to check the part # on my spare tomorrow.
ACTIVESHACK is offline
Old 08-05-2008 | 08:05 AM
BillR's Avatar
OSO Moderator
Different? In what way?
Are you still getting fuel in the oil?
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-05-2008 | 09:01 AM
The hose barb for the vent line on my old ones came stright off the pump and on the new ones it turns up on a 45. I change the oil in mine every time I do the engines and before every poker run. The oil still smells gassy when I change it but it doesnt build up above the drain hole.
Old 08-05-2008 | 12:31 PM
Bill take a look at these and see if they will work .(www.racepumps.com/index.html)
formula 382 sr-1 is offline
Old 08-05-2008 | 05:34 PM
Thats the # on my spares I carry with me. I bought them last July after I had problems. They have the curved vent line like I mentioned in my earlier post which is different from the ones that came on the motors.
Old 08-06-2008 | 07:38 AM
BillR's Avatar
OSO Moderator
I don't think they will.
CV products does www.cvproducts.com part # CV2630
I may go that route and be done w/ the Merc Crap
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-06-2008 | 08:46 AM
StrikinLightnin's Avatar
I have 'em in my boat with no problems.
They're completely rebuildable.
I haven't changed gear oil yet so that will tell the tale if they leak like the stockers.
A shop nearby does a lot of stock car engines and I see CV pumps on them.
D
StrikinLightnin is offline
Old 08-06-2008 | 09:22 AM
$418.26 a piece
