496 mag won't start >
496 mag won't start
496 mag won't start
Old 08-02-2008 | 08:57 PM
Question 496 mag won't start
used the cruiser today and one of the 496 mags just shut off while cruising and will not start. just turns over, but will not fire up. Any idea what went bad?
Thanks!!
homesite is offline
Old 08-02-2008 | 08:59 PM
jeff32's Avatar
out of fuel???
jeff32 is offline
Old 08-02-2008 | 09:34 PM
its got fuel
homesite is offline
Old 08-03-2008 | 08:00 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Put a feul gage on the shrader valve located on the fuel rail and check to see how fuel pressure you're producing. Should be like 40-43. Does it act like it wants to start, or does it just turn?
Reckless32 is offline
Old 08-03-2008 | 08:29 AM
GO4BROKE's Avatar
Check the barrel connector, make sure it's tight.
[img][/img]
GO4BROKE is offline
Old 08-03-2008 | 10:37 AM
It sounds like it wants to start. What and where is the barrel coonector? thanks
homesite is offline
Old 08-03-2008 | 10:28 PM
Thanks!!
crank trigger
tunertech is offline
Old 08-04-2008 | 08:51 AM
KISS first. check grounds and connectors before throwing cash at it .
ZP'd is offline
Old 08-04-2008 | 09:33 AM
Do you have good spark while cranking? What about vapor lock? Does it start after it cools off?
Edward R. Cozzi is offline
Old 08-04-2008 | 09:39 AM
One of my Mag H.O's shut down suddenly after I got the boat up on plane. Turned out the computer was the cause, which sucked because they are expensive, but an easy repair!
weekend warrior is offline
mg503
Baja
14
04-03-2013 04:50 PM
Roger Eriksen
6
07-15-2008 01:19 PM
TeamPSI
23
12-10-2007 05:23 PM
Wally
03-16-2007 07:22 AM
ursus
13
04-29-2002 11:28 AM
