Lots of parts for sale - please have a look
I've got a bunch of parts for sale - getting out of the sport - please have a look.
Item list:
Mercruiser Bravo 1 Transom assembly with backing plate - bought new, never installed
Mercruiser Bravo 1 Outdrive Max Worx/Imco/Motion- bought used on fresh rebuild, 0 hours, never installed
Imco Extension Box (3" raise) with wings, backing plate and Bravo drive shaft - bought used, excellent condition
632 Cubic Inch Big Block Chevy Engine - 900 HP - bought used, never installed, excellent condition
CMI Tube Top Headers - for Bravo setup - bought used with motor, never installed, excellent condition
Aeromotive A1000 fuel pump with regulator - bought new, never installed
Mercruiser Bravo Trim Pump - bought new, never installed
Imco Steering Wheel White - with hub bought used, excellent condition
Imco Polished pulley set - bought used as new takeoffs, never installed, excellent condition
Mayfair Full Hydraulic Steering System for Bravo single - bought new, never installed
Delco High Output Marine Alternator (105 amp) - bought fresh rebuild, never installed
Hardin Marine High Performance thermostatically controlled Oil/PS cooler - bought new, never installed
Throttle - Single/White bought used/take off, never installed
Throttle - Twin/Black bought used, never installed
MSD 6AL ignition - bought new, never installed or used
Trick Marine Trim Switch - White
More info:
http://www.247liquidators.com/boat/parts4sale.html
Thanks.
Item list:
More info:
Thanks.
Bob, sent email for pulley set and twin black throttles.
Trick Marine Trim Switch! I would def keep that if I were you, collectors item, worth couple G's minimum ...
I never received any instructions with the trim switch but you could easily check the action with a battery & circuit tester.
http://www.247liquidators.com/boat/trimswitch.html
$350.00 for the fuel pump & regulator. They have never been out of the box except to take pics.
http://www.247liquidators.com/boat/fuelpump.html
