496 changing sparkplugs ? >
Old 08-04-2008 | 01:17 PM
Angry 496 changing sparkplugs ?
35 fountain twin 496's the rear two center plugs how do you people get to them?
sonic28 is offline
Old 08-04-2008 | 11:19 PM
Wink
Why are you changing plugs. these are platunum tipped plugs and if they are running ok they should just about outlast the engine and the boat?
Best Regards,
Ray @ Raylar
Raylar is offline
Old 08-05-2008 | 07:18 AM
Registered User
Thay are diffacult to get but can be done. I have seen several engines with those plugs that fail between 200 and 300 hours. The #7 plug is the hardest.
clpbs is offline
Old 08-05-2008 | 07:31 AM
Red face
hi Ray
thank you, you stand correct I thought I had a bad plug and found out is was a wire.I changed one plug and said I have to change all what a mistake that was.I had to pull the fresh water tank on the port side and the holding tank on the starboard side.I just have a problem with the rear two in the center do to the fact I am a little portlie lol on me.So who was the brain child that said size matters not in this case.
regards Paul
sonic28 is offline
Old 08-05-2008 | 11:33 AM
A tech deep at Merc suggested they should be changed every year...
verbi69 is offline
Old 08-05-2008 | 12:00 PM
They are also in the business of selling parts, what do you think they are going to say?
I'm with Ray, why change them if there is no reason to think they are not working. How many times do they actually fire over the lifetime of a marine motor? Think of how often your car's plugs fire and you probably don't touch those for the life of the car!
techman is offline
Old 08-05-2008 | 12:25 PM
I thought merc recommended changing them at like 300hrs.
Griff is offline
Old 08-05-2008 | 03:43 PM
Registered User
I think in our area it may have something to do with the saltwater use. My shop has had three boats in six months with some bad plugs.
clpbs is offline
Old 08-05-2008 | 03:56 PM
then there is something else wrong. modern plugs with modern ignition , in nominal circumstance should last exactly as ray says.
stevesxm is offline
Old 08-05-2008 | 04:20 PM
hillbilly24's Avatar
The only real valid reason for changing platinum plugs is that even the best quality stainless plugs will eventually corrode and then it is a real pain to get them out. For boats that sit in the saltwater or in any salt environment I recommend changing them every couple years regardless of hours. If you have to pay some one to extract one plug that snaps at the base it will cost alot more then a set of plugs.
hillbilly24 is offline
