Launches in Southwest Michigan or Northern Indiana
Heading to Chicago for the Air & Water Show Aug. 15 - 17.
Anyone have any suggestions/advice for a boat launch in far Southwest Michigan or Northern Indiana?
smdude:
Thanks for your input. Doing some investigation online, it looks like the New Bufflo marina is pretty nice. Do you happen to know how far it is across the lake to Chicago from New Bufflo?
Thanks again.
Thanks again.
I think it is around 40-45 miles from New Buffalo. Michigan City is another 15 min by car and there ramps are OK, a little short but very usuable. Michigan City is 32 miles from the City.
Payton:
Thanks for the information on the Portage ramps. Looking at a chart, it looks like Burns "ditch" Waterway is quite shallow.
What are the water levels like this year. I would like to have 4ft. minimum to be safe.
Between the two ramps, Portage Municipal and Doyne's Marina, which one would you suggest.
Thanks again.
Thanks again.
Payton:
Thanks again.
Thanks again.
SoryI didn't see this sooner.
MM gave you the correct info. Both ramps are fine this year. Water is 9" above last year.There are several 34-42' offshore boats launch at both ramps.
Portage Muni. is nicer place, but when the weather is nice for small boats the parking lot fills up by noon. Then it all shuts down. Doyne's stays open regardless of how full it gets.
Portage has no current to deal with. Doyne's has constant current. I use Doynes all the time just because I leave myboat there. Loading can be tricky on a windy day, with my staggered engines.
Please, no powering on your trailer at either place. Your prop wash digs hole in the bottom, then when the water drops again the trailes will sit uneven.
You also have East Chicago and Hammond as options. Robert Pastrick Marina as East Chicago is where we hold the Chicago Poker Run, nice big wide ramp and parking shouldn't be too much of a problem. Hammond is my home port, and though it's the closest to downtown (appr. 14 miles), unless you get there REALLY early and plan to leave REALLY late, parking and the ramp are gonna be REALLY crowded.
