Aluminum Fly Wheels >
Aluminum Fly Wheels
Aluminum Fly Wheels
Old 08-09-2008 | 11:36 AM
Little Tommy's Avatar
Default Aluminum Fly Wheels
Anyone running these? LT
Little Tommy is offline
Old 08-09-2008 | 12:45 PM
Registered User
Discussed several times this year- run a search. Way too much good tech info was shared to re-type.
Chris Sunkin is offline
Old 08-09-2008 | 01:44 PM
I use aluminum 8 lbs flywheels and they work fine. Biggest advantage I see is less weight in the boat. Others use 30+lbs steel. At best you are splitting hairs...most/all comments based on opinions with very little fact...I don't have any either
BenPerfected is offline
Old 08-09-2008 | 02:14 PM
articfriends's Avatar
I have talked/dealt with 1/2 dozen racers in the course of doing gear treatments on bravos,everyone of them was running fidanza aluminum flywheels,don't know any pleasure boaters running them but I ran one on my last boat,a non chevy powered jet boat and it revved like a suzuki when it came out of the water,Smitty
articfriends is offline
Old 08-09-2008 | 03:56 PM
jdnca1's Avatar
I ran alum flywhell on an old 632" NA motor with no issues. As artic stated...they rev incredibly fast when the load is off...You will definately get peoples attention any time you free rev it... With big cams around the dock they can be a bit touchy...meaning a touch of throttle in gear for idle, etc goes a.....long.....ways...
jdnca1 is offline
Old 08-09-2008 | 04:38 PM
Registered User
Aluminum is great for someone highly skilled on throttles who needs that extran 2 seconds of acceleration out of each turn on the racecourse and is willing to live with the idle and free-rev issues.
Not me.
Old 08-09-2008 | 05:02 PM
Strip Poker 388's Avatar
Rob
did mercury racing ever use them on any motors?
Just think when a drive line part fail how far past the rev limiter it would buz,Mine was 900rpm above it
Strip Poker 388 is offline
Old 08-09-2008 | 05:41 PM
Registered User
I believe the 482FI did. That was many moons ago. Eickert does.
Old 08-09-2008 | 06:11 PM
Wahoo ATV's Avatar
Racer
Tyler Crockett makes a very good AL flywheel. You should call him if you want info.
Wahoo ATV is offline
Old 08-09-2008 | 06:12 PM
JCPERF's Avatar
The idle quality goes to sh1t with aluminum flywheels.The acceleration is night and day though
JCPERF is offline
