Merc 454 needs rebuild , RPM intake , large oval ports >
Old 08-12-2008 | 12:38 PM
Default Merc 454 4bolt main needs rebuild , RPM intake , large oval ports
454 Merc needs rebuild , Edelbrock rpm intake , large ovalports ( post 1 of 1)
454 Merc out of my boat,blew a headgasket and cooked a piston ,
will throw in the heads if you want them but they are peanut ports, .
Engine was still running and had good/normal oil pressure and water temp before I pulled it out. Extremely clean engine inside and had about 300 hours.
No fuel pump boss so I think its a gen 5 but it does not have a roller cam .
No oil pan,intake,flywheel,balancer or timing cover.. $300 picked up in Lago Vista (30miles NW of Austin)
Edelbrock rpm intake for BBC , painted orange , $100 picked up
large oval ports
#6272292
show up as 70-77 454,chevelle,corvette,etc
crane dual springs and normal car style rebuild.
Do not have hardened seats.
$300 picked up
HTRDLNCN is offline
Old 08-12-2008 | 01:03 PM
I have a great 502 mag with 470 hours on it if you need a replacement. The 502 has never even had a valve cover removed...just a solid stock 415 HP motor.
pslonaker is offline
Old 08-12-2008 | 01:47 PM
thanks but a little late ,
bought a Merc 502 shortblock for on ebay
and just had it gone thru at the machine shop.
Basically ended up with a balanced and fresh 502 shortblock for $2000
Just need to locate some proper heads now.
HTRDLNCN is offline
Old 08-12-2008 | 02:30 PM
Bummer...I have heads...large oval ports with the heart shape combustion chamber off of a 2001 454 MPI already setup for a roller...$500.00...got pics if you want to see...email me at [email protected] and I can send them to you. You are just down the road a piece from me anyway.
Old 08-12-2008 | 03:34 PM
I didnt think Merc was using normal ovalports since the mid 80s?
Just peanuts and squareports?
Definately intrested.
Ill shoot you an email.
HTRDLNCN is offline
Old 08-12-2008 | 04:48 PM
If you still have this stuff after the weekend, I will come get all of it. I use those parts a lot.
Jeff
jeff1000man is offline
Old 08-12-2008 | 06:42 PM
Registered User
What Gen and how much? I may have some interest.
320es is offline
Old 08-12-2008 | 07:14 PM
For those that asked its a 4bolt main block
HTRDLNCN is offline
drpete3
Do It Yourself, Boating on a Budget
4
07-19-2008 02:47 PM
BillFormula
Wanted
2
04-28-2008 12:56 PM
Tee
4
01-19-2003 06:08 PM
blue thunder
0
11-23-2002 12:26 PM
blue thunder
38
10-11-2002 05:10 AM
