454 cam replacement
Old 08-12-2008 | 08:27 PM
Default 454 cam replacement
I've read a ton of posts on this, but still haven't found what I'm looking for.. does anyone have the specs for a stock '89 454 mag cam? The manual has lift, but no duration, centerline, etc. Also, what roller cams have people had luck with? I'm hoping to maintain close to stock performance, and not have to change valve springs.
JB440 is offline
Old 08-13-2008 | 02:17 PM
Default Jb
The stock cam was a Crane Cam, flat tappet design i believe. I have just changed to a Crane 168731 Hy-roller that along w/ Iron Eagle heads allowed me to pull almost 500 hp on my .060 over 400 HP mercs.
Wannabe
wannabe is offline
Old 08-14-2008 | 07:54 AM
KAAMA's Avatar
Call "RMBuilder"/Bob Madara of Marine Kinetics in N.Y....he is the cam expert and can dial you in on whatever you're looking for. 585-654-8583
KAAMA is offline
Old 08-21-2008 | 08:56 AM
PatriYacht's Avatar
You'll have to change the springs to go with almost any cam change. Those springs are pretty wimpy and don't have the capacity for high lifts.
PatriYacht is offline
Old 08-21-2008 | 01:26 PM
The cam for the 454mag/365 hp is .510/.510, 220/220 duration.
Griff is offline
Old 08-21-2008 | 08:24 PM
Yes he is and yes he can !!!
formula 382 sr-1 is offline
Old 08-21-2008 | 08:43 PM
The good thing is the 365HP really wakes up from a cam and exhaust upgrade. Dont bother swapping cams unless you have some decent exhaust.
If I were going to upgrade a 454 mag, I would
install good exhaust,
roller cam upgrade
roller rockers
switch to a holley 4150 800CFM
good intake
MILD THUNDER is offline
Old 08-21-2008 | 09:36 PM
You can put in a flat tappet cam from an early generration 502 carbed engine and leave everything else alone and wake it up a little.
That way you can still use the old srings and exhaust.
jeff1000man is offline
He is the GURU
Old 08-22-2008 | 07:34 AM
call ultradyne and talk to Tim golsbe he's the man they did all the cam engineering in the 80's for mercruiser big block and small block chevys
Ultradyne Bullet Racing Cams at (662)893-5670
Rockfish71 is offline
