VHF Antenneas....something smaller? >
Old 03-03-2002 | 06:30 PM
Default VHF Antenneas....something smaller?
MUST I have a big 6 or 7ft antenna for a VHF or is there a small high tech version I could get that wouldnt be so clumsy and obtrusive and still get good or decent reception......thanks Doug.
pullmytrigger is offline
Old 03-03-2002 | 06:44 PM
Shooter's Avatar
Charter Member #300
Shakespeare makes a small 3' SS VHF that works well. If you're not going way offshire it works well. Check out West Marine, I use one and never had a problem.
Shooter is offline
Old 03-03-2002 | 07:02 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I use the 3'ss one also. Works great for my needs. And not noticable from a distance, unlike the 8' white ones. But you do loose some distance. VHF, line of sight.
US1 Fountain is offline
Old 03-03-2002 | 07:47 PM
C_Spray's Avatar
Diamond Member #001
There are several versions of 3' stainless whip antennas from Shakespeare. I use one with a quick-disconnect feature (Shakespeare #5242), where the whip comes off of the base via a 1/4-turn connection. There is also a fold-down version. BoatUS (#307113) and West Marine are your best bets. Reception/transmission distances will be shorter than a longer antenna, but will still reach several miles.
C_Spray is offline
Old 03-03-2002 | 08:17 PM
Thanks guys! The guy at the marine store I deal with said my only choice was a whip although to be fair Im probably one of only a handful of "radical go fast boaters" he deals with. Our needs are different, I knew I would get the facts here, thanks again........Doug.
Old 03-05-2002 | 11:07 AM
My 3 foot antenna is mounted under the gunnell (sp?) next to the hull. It bends a little as there is less than 3' of vertical room in this area. You can not see it, but there is serious loss of range with this setup.
Chart is offline
Old 03-05-2002 | 12:39 PM
Mike J
I have had good luck using
the "Stowaway" #5911 by
Shakspeare, It has a suction cup and is only
10" tall.
WestMarine #519058
Worked well for the Ski
race LongBeach to Catalina
Mike J.
Old 03-05-2002 | 04:00 PM
Airpacker's Avatar
Hey Doug,there are several base loaded 36" ss antennas available.the one I put on my power play works pretty well although I wouldn't say it has ocean going range.Got it from short wave marine electronics in bronte harbour.
Airpacker is offline
Old 03-05-2002 | 05:59 PM
velocity260's Avatar
boaters world carrys them thats where I got mine, west and boat us dindnt have them. 3' stainless whip
velocity260 is offline
Old 03-05-2002 | 06:47 PM
Tonto's Avatar
I have the same set-up as Chart does. The 3' ss antenne is mounted inside the boat on a bulkhead. You do not see it from the outside of the boat, but you also have a good reduction in the performance of the radio. Just an idea
Tonto is offline
