Looking For A Mini Hawk,,,,,,,,,
Hoping To See If Theres A Mini Hawk Around, Or Maybe If A Fellow Member Has One. Structurally Sound Is All Thats Needed. Cosmetics Are No Issue.
if u can send them an e mail or pm for me so i can try to pick one up.
i m looking to get one so i can put a sea doo rxp 255 hp engine with a straight shaft ind rudder steering in it.
hopefully this years winter project.
Are you aware of the bounce factor they have? and getting them on plane wasn't the easest thing eather. Good Luck keep us posted.
there was the original, then someone took the boat and cut a pad into it to remove the hop.
were in the middle of dialing in a mini cat with an outboard on it at present to get used to the scale for now.
were not going for top end as much as acceleration. i plan on skying this thing out side the inlet over here.
bo, call adnny at swipes, he is the "hotdog" guy...i'm sure he will sell you a hull, amybe even be able to help with some specifics.
