do i need this thrust washer? >
Old 08-20-2008 | 03:29 PM
Default do i need this thrust washer?
Im running a solid hub 23p and im wondering if the thrust washer behind it is necessary. It holds the prop out quite a bit and the prop nut is not getting a 100% grab.When i run my 4 blade with flo torque kit, the thrust washer is fine. By removing it for a better and tighter( and safer) fit , do i run the risk of wearing out the built in washer already on the shaft? Some input would be nice...thanx
twisted switzer is offline
Old 08-20-2008 | 03:56 PM
Need more info. A solid hub old cleaver does not use a thrust hub. A solid hub mirage has a small diameter thrust hub. Why do you think tighter is safer? I'm not aware of a thrust hub built on the shaft; what drive do you have?
MOBILEMERCMAN is offline
Old 08-20-2008 | 04:29 PM
c_deezy's Avatar
You aren't putting the thrust washer on the shaft upside down are you?
c_deezy is offline
Old 08-20-2008 | 08:08 PM
The drive is a bravo 1 w nose cone,the prop shaft has a built in gold colored stopper. What im saying is that the solid hub prop,when the thrust washer is on,sticks out so far that im barely getting a 50% bite with my prop nut. So yes, i think that is unsafe as far as keeping my prop goes! That said,when i remove the thrust washer and put it on,it seems to countersink into the outdrive nicely. The prop is a 23p mirage solid hub (bought used but very new) and did not come with any type of washer....thanx fellas
Old 08-20-2008 | 08:29 PM
I got you. That gold washer is stuck on there. Give it a tap with a hammer or gentle pry it loose. There are many different thrust washers. The mirage has one it will be a brass color and fits in the prop. Much smaller in diameter then others. The thrust washer has a tapper that rides on the tapper on the prop shaft. When every thing is right there will be 3 threads showing at the prop nut and when you push the prop forward and rotate it spins with out touching anything. Check out the trust hub in your mirage. When the thrust hub wears out it allows the prop to move forward and it can damage the gear housing.
Old 08-20-2008 | 09:52 PM
Well in boating,and like most things, the stupid question is the one you didnt ask so Thanx Jim.....ill check it out asap...i bet what im calling a built in stopper is in fact the small washer that goes inside my 23...if so than it must be fairly worn out because its down the shaft a good bit and i was seeing more than 3 threads.. it could be from another prop completely,im not the original owner of the boat or the outdrive....i visited Lake Travis for the first time back on Memorial day and loved it..thats a nice area yall boat in,man.....thanx again for your time
Old 08-25-2008 | 07:34 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
We have the mini thrust washer you need if your still searching.
I have out of the office for over a week so I missed this thread.
Let me know if I can help!
[email protected]
bbladesprops is offline
Old 08-28-2008 | 09:15 PM
ENFORCER24's Avatar
if memory serves me the thrust washer for the solid hub mirage is a part # 14359 , hope it helps
ENFORCER24 is offline
Old 08-29-2008 | 08:51 AM
spazboz's Avatar
That washer seats on a tapered part of the shaft, and in my experience its common to see it stuck to the shaft, and not come off with the prop. sometimes it can be pretty stuck, but it'll come off!
spazboz is offline
Old 08-29-2008 | 09:53 AM
Smile
Often they will stick in the prop too.
That is the correct part number.
[email protected]
