Iron Heads
Old 08-21-2008 | 09:49 PM
Default Iron Heads
What are the best iron heads for an HP500 (carb) motor ? We lost one last weekend and it's time to rebuild both. These motor have 950 hrs on them if the blocks are good then we will reuse them but the heads must go.
Joby
formula 382 sr-1 is offline
Old 08-22-2008 | 05:18 AM
J.B. Marshall's Avatar
JB Marshall
Wow! what kind of motor work (maintenance) did you do to get 950 hrs out of them?
J.B. Marshall is offline
Old 08-22-2008 | 06:39 AM
Registered User
Dart Iron eagles. Call Mark precision Marine he can help you out.
clpbs is offline
Old 08-22-2008 | 07:43 AM
Registered User
Yep- the Iron Eagle's are about the best. If you meant OEM, the 990 casting is about it. The 088 is good too- probably what was on your motor.
Chris Sunkin is offline
Old 08-22-2008 | 07:56 AM
KAAMA's Avatar
950 hours on a pair of Merc HP500's is pretty good---I'm sure they're gettin' pretty tired. Also, if you're looking to do a cam change/upgrade call RMBuilder/Bob Madara of Marine Kinetics in N.Y. He will get you the correct profile that will work the best for your application and what you want to do with the boat. 585-654-8583
KAAMA is offline
Old 08-22-2008 | 08:46 AM
PatriYacht's Avatar
Talk to Jim Valako about his Iron Eagles. He ports them to flow as good as a set of AFR's. They're good for a hundred hp or more over the GM heads.
PatriYacht is offline
Old 08-22-2008 | 09:00 AM
Registered User
http://hometown.aol.com/valakoracehe...raceheads.html
Old 08-22-2008 | 07:51 PM
JimV's ported Dart IE heads were a big part of my 800+ HP results
BenPerfected is offline
Old 08-22-2008 | 08:41 PM
t500hps's Avatar
21 and 42 footers
I have Iron Eagles on my modified 500's..........
t500hps is offline
Old 08-22-2008 | 08:46 PM
Default heads
I got 2 sets of GM 990 iron heads if any one wants them
redcorvetteman3 is offline
