What type of GASKET to use on the fuel sending unit? >
Old 08-22-2008 | 10:57 AM
Default What type of GASKET to use on the fuel sending unit?
I want to take my sending unit out that I installed 6 years so I can check to see how much gas is actually left when the gauge reads empty (like it is now) before I refuel.
The gasket/seal is listed as N/A. As I remember it was a rubber gasket.
If I make a cork gasket will it last? It’s the standard 5 hole circle sending unit.
1BIGJIM is offline
Old 08-22-2008 | 12:25 PM
Wobble's Avatar
SORE MEMBER
cork used to be standard, cork plus a little gasoline resistant sealer should work well
Wobble is offline
Old 08-22-2008 | 12:27 PM
Livorsi senders use a cork gasket, so you should be fine making one yourself.
Griff is offline
Old 08-24-2008 | 07:06 AM
fund razor's Avatar
I prefer the rubber. You can find them. I just googled and found one on shootandhunt.com catalog for 8.73.
There was also one being made by Tempo.
I like the actual rubber gasket kit because it comes with the screws that have sealant near the shank of the screw which crushes slightly making up for any slop or gap where the screws meet the top of the sending unit. Huge bonus.
Also... the rubber has a staple in it. I assume that this staple.... having no other reason to live... acts as a bond between the ground of the tank and the top of the sending unit.
Might be worth a lil search and a few bucks to get a legit gasket and have no questions whether the one that you engineer from cork is completely sealed.
No matter what you decide. Good luck. I have done that job many times. Hope for a cool day and a nice breeze.
fund razor is offline
Steve_H
1
07-19-2004 08:53 PM
SKRAMER
16
04-08-2004 09:16 PM
alcor
4
02-02-2004 07:07 PM
halffast_2003
1
07-21-2003 04:20 PM
GregP
5
04-19-2002 08:13 AM
