Switchable muffler question >
Old 08-26-2008 | 01:09 PM
NJDave's Avatar
Default Switchable muffler question
I was out on Sunday & went to switch on my mufflers pulling into a restaurant & no mufflers. The boat is an Eliminator Daytona 28 Cat
Twin HP 500’s. The 4 mufflers all have a solenoid & none are working. Typically when I throw the switch you hear them all click pretty Loud . Now I here a clicking in the radio thru the speakers but no solenoid action. My question is if the switch on the dash is working
then if one solenoid is bad do they all not work? Just does not make any sense?
NJDave is offline
Old 08-26-2008 | 01:20 PM
Knot 4 Me's Avatar
Check for a circuit breaker on the harness for the solenoids. If it is not tripped, then pull the connections off the solenoids and make sure they are not corroded.
Knot 4 Me is offline
Old 08-26-2008 | 02:09 PM
GPM
Are they the Teague muffler tips ?
GPM is offline
Old 08-26-2008 | 03:27 PM
NJDave's Avatar
Are you saying that there might be an inline circut breaker? I have never seen that. But I will check.
NJDave is offline
Old 08-26-2008 | 03:29 PM
NJDave's Avatar
I do not know. I belive they are factory installed so whom ever eliminator would use in 1999.
Where would I see who's muffler tips they are?
NJDave is offline
Old 08-26-2008 | 03:36 PM
If the solenoid that switches them is inside the transom then they are probably Teagues.
Griff is offline
Old 08-26-2008 | 04:07 PM
Knot 4 Me's Avatar
Actually, I was thinking of Corsa which does have a breaker. Not sure on mufflers.
Old 08-26-2008 | 04:55 PM
NJDave's Avatar
Then yes they are Teagues. The people I bought the boat from know Bob Teague & would guess they had his shop install them if the boat did not have them from Eliminator when new. So what do you think is wrong? Why would all 4 stop working if 1 is bad or are they wired that way ? Any help of where to look for the problem would be helpful.
NJDave is offline
Old 08-26-2008 | 08:28 PM
GPM
If the solenoid catches fire they're probably Teagues. Bought 2 sets brand new, they burned up in less than one season.
GPM is offline
Old 08-26-2008 | 09:05 PM
Can't beleave all four burnt out at the same time. I would check for a blown fuse first and then a loose wire.
Jeff P31 is offline
