Gen vi flywheel
Old 08-26-2008 | 10:35 PM
Default Gen vi flywheel
HELP!!!
What flywheel do i need for a gen vi with cast iron crankshaft? It is a reman but not a MerCruiser.
caybraca is offline
Old 08-27-2008 | 12:12 PM
CPPerformance's Avatar
Check these out------>
http://www.cpperformance.com/SearchR...CategoryID=437
Pick out the appropriate one you would need, just need to know whether you need internally or externally balanced, block or bellhousing mounted starter, and steel or aluminum.
CPPerformance is offline
Old 08-27-2008 | 04:15 PM
The flywheel it has on is 3973457 and the crank is 10114188 but the engine has a vibration i think it may be the wrong flywheel. Do anyone know the gm part no?
caybraca is offline
Old 08-27-2008 | 06:41 PM
DONT use a cast crankshaft. I learned the hard way if its goin in a boat
963b is offline
Old 08-27-2008 | 07:44 PM
Cay,
I dont have the part number here at home, but the flywheel for a 1999 Chevy truck 454 should be the correct one. I do have the correct part number at the shop, but usually do not go online during the day due to a dismal dialup connection. Feel free to call me in the morning and I can give you the correct GM part number. 301-843-5700
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 08-28-2008 | 12:35 PM
Cast crank this is the fylwheel you need see the link get the part number and call or go to the gm dealer and order it http://www.perfprotech.com/store/pro...169,25622.aspx
Rockfish71 is offline
Old 08-28-2008 | 12:41 PM
http://www.bucksengines.com/Data/22.pdf
Old 08-28-2008 | 07:50 PM
Talking
here's more information
Part # Dia" Clutch Dia" Teeth Application
14085720 12 3/4 10.4" 153 65-69 Mark IV, Lightwweight (15 lbs), nodular iron, two-piece seal, internally balanced.
3963537 12 3/4 10.4" 153 70-90 Mark IV external balance 454, 15 lbs
3991469 14" 11" 168 66-69 Mark IV internal balance 454
3993827 14" 11" 168 70-90 Mark IV external balance 454
14096987 14" 11" 168 91-up Gen. V/IV external balance with 4" stroke forged steel crank, 454, 502
10101169 14" 11" 168 91-up Gen. V/IV external balance with 4" stroke cast nodular iron crank, 454, 502
http://www.stingray.nu/se/index.htm?/tips/flyflex.htm
Old 08-30-2008 | 02:43 AM
Thanks guys this the gm part no. right, how can i get the casting no. for this? (10101169 14" 11" 168 91-up Gen. V/IV external balance with 4" stroke cast nodular iron crank, 454, 502)
GUSTAV IS HERE IN THE CAYMAN ISLAND CAT 2 NOW!
caybraca is offline
ddabal
Do It Yourself, Boating on a Budget
5
07-08-2008 01:40 PM
Nordicflame
6
10-19-2007 08:18 PM
cooltoys61
10
09-07-2004 11:33 PM
excaleagle42
4
04-24-2004 08:49 AM
Shah Mat
1
03-19-2004 10:59 AM
