Opinions on Mercruiser 165 6 cyls with type R outdrives in a 1979 Sea Ray 24' SRV >
Old 08-27-2008 | 01:15 PM
phughes69's Avatar
Default Opinions on Mercruiser 165 6 cyls with type R outdrives in a 1979 Sea Ray 24' SRV
What are peoples opinions on this boat and propulsion
1979 24' Sea Ray SRV Sedan flying bridge twin Mercruiser 165 6 cylinders with type R (pre alphas) outdrives. The boat looks good has normal wear for a 30 year old boat. the motors started right up and ran smooth. (the motors were cold). Hull looks good. Bilges look clean. I'll poke around the transom area and the stringers some more next time I inspect the boat again. Any body have one of these boats before and what good and bad things can you tell me about it
phughes69 is offline
Old 08-27-2008 | 02:04 PM
wrinkleface's Avatar
Buy boat, replace engines w/ 1075's & # 6's & U will B good 2 go!!!!! Sorry, could not help myself!!! Work'n on it though!!!!
wrinkleface is offline
Old 08-27-2008 | 03:18 PM
Back in the day that was a pretty good engine.
salesmanship is offline
Old 08-27-2008 | 04:45 PM
phughes69's Avatar
Does anybody have an opinion on the type R outdrive?
Old 08-27-2008 | 04:50 PM
That drive and engine was popular and well matched. I would check all the normal things like gear lube, bellows, shift cables ,transom and stringers. Given its fresh water and if its well maintained I think it could serve you well.
MOBILEMERCMAN is offline
Old 08-27-2008 | 04:55 PM
johnny g's Avatar
How could anyone say anything bad if its still going after 30 years? Must be a pretty reliable set up.
johnny g is offline
Old 08-27-2008 | 06:34 PM
Panther's Avatar
Frank's Marine Service
Jimmy, I thought the R drive was still an Alpha, just an older case design and no oil holes and slightly different shift mechanism....and stood for "Recent"... the MR was "More Recent"...then the Alpha 1 and Alpha II????
Panther is offline
Old 08-27-2008 | 06:51 PM
Alpha designated new lower gear design. The gears repelled and the older came together when the rotated. Alpha or MR have the cover nut under the water pump base and no pin on driveshaft..
Old 08-27-2008 | 07:01 PM
hillbilly24's Avatar
"R" stands for Revision and "MR" is major revision
hillbilly24 is offline
Old 08-27-2008 | 07:08 PM
Panther's Avatar
I guess 10 years being out of the field has finally taken its toll on my memory!
Panther is offline
