spark plugs
Put in what the head manufacturer recommends for starting point and then check plugs for location of the heat marks and change heat range, if you need to, accordingly.
Note: when doing this it's better to start with a colder plug than it should end up with than with a hotter plug. A colder plug will just foul faster whereas a 'too hot' plug can seriously wound your motor. Most head manufacturer's recomended starting point recomendation is on the cold side.
