whats the difference
Old 08-28-2008 | 07:11 PM
Default whats the difference
hey guys
can anyone tell me the difference between a conventional prop and a surface piercing prop i seen a turbine boat with a asd 8 and the prop looks like a conventional prop i think it was an osborne
cheers gerard
gerard is offline
Old 08-28-2008 | 07:16 PM
Its position behind the boat. High rake plays a part. Cleavers may have been the first used in a surfacing situation.
MOBILEMERCMAN is offline
Old 08-28-2008 | 07:17 PM
Conventional = cheap$ Surface (cleaver) = expensive$
40FlatDeck is offline
Old 08-28-2008 | 07:35 PM
yea i have a surface drive at the mo but was thinking about trying on a conventional prop how would it work if at all what makes the props so different
cheers gerard
gerard is offline
Old 08-29-2008 | 05:31 PM
back to top
gerard is offline
Old 08-29-2008 | 09:32 PM
The surface drive props are stronger,if you put a conventional prop on there you are going to lose some blades
BOBCATMATHEWS is offline
Old 08-30-2008 | 06:28 AM
so if i had a strong convetional prop it will work
gerard is offline
Old 09-02-2008 | 10:45 PM
I doubt it.
A freind has thrown blades off of 6 blade hering props twice behind diesel power with surface drives.
Griff is offline
Old 09-03-2008 | 04:33 PM
What is the advantage of surface drives, beside the rooster tail?
SeeYouThere is offline
Old 09-03-2008 | 04:40 PM
wstultz's Avatar
Social Distortion
Less drag, more speed, smaller draft. Several advantages, Not many disadvantages. Some may say they are harder around the dock but once you get used to it there is no problem. I never had much problem docking when I had a rig with some arnesons. Bulletproof.
wstultz is offline
velocity27
Detailing, Painting, & Fiberglass
10
04-13-2008 08:08 AM
Westcoast
02-03-2007 03:35 AM
stonecaster
09-22-2006 08:35 PM
hdcuda
Scarab
2
07-13-2004 12:14 AM
SinkorSwim
Sutphen
5
11-19-2002 01:14 PM
