help water in bildge >
Old 09-01-2008 | 09:06 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default help water in bildge
thought it was from motor but its not last time out in 4.5 hours got 25 gals in bildge
have a cradle lift and lowered into water with out boat running could see a small trickle of water from under strarbord gimbal area \
I changed drive shaft bellows last year any other thing i should look for besides shift bellows?.
boat is on trailer and cani see any cracks in that belloes but have not removed drve yet for total inspection
any other ideas
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 09-01-2008 | 09:35 PM
I had a hose from the sea pump leaking.... small crack in it and it eventually broke wide open. Check all the lines first.
niceguy is offline
Old 09-01-2008 | 09:42 PM
klaw's Avatar
all hoses are good boat in water not running i can see water coming in slowly from bo top edge og bottom of inner gimbal
klaw is offline
Old 09-01-2008 | 10:23 PM
offthefront's Avatar
make sure the hose connector is not cracked (Part #20) ....
offthefront is offline
Old 09-01-2008 | 10:59 PM
Make sure the transom assy itself it tight. Other than that, its a bellows or loose hose connection.
800XCR is offline
Old 09-02-2008 | 02:40 AM
hillbilly24's Avatar
The best thing to do is to get in there with an inspection mirror and a flashlight. It could be quite a few different things. The u-joint or shift bellows, the y-pipe or block off seal (depending on your setup), the steering shaft seal or even the gimbal housing seal itself could be leaking. Without getting in there with a mirror and a flashlight you are just guessing.
hillbilly24 is offline
Old 09-02-2008 | 05:19 AM
klaw's Avatar
thanks for the responses
The boat has cmi exhaust with the y pipe removed and has the need block off plates will put back in onthe trailer and see if I can get a better look it's a twin so real he'd to get a good view I tried my helmet cam on a rod but could not get into position if I can't get a look may just yank motor reinstall drive the look will be easy then
klaw is offline
Old 09-02-2008 | 10:07 AM
blue thunder's Avatar
The lower bolts that hold the transom assembly on are anodes and will rot out and let water in. At least on late eighties bravos, not sure about trs if that is what you have. The water leak will look just like you described.
BT
blue thunder is offline
Old 09-02-2008 | 11:21 AM
klaw's Avatar
they are 1989 bravos I have ordered a video note scope and will have Thursday and gt a good look can I replace without pulling motor if it's the anode bolts?I am putting odds on that is the roblem
klaw is offline
Old 09-02-2008 | 12:42 PM
I replaced mine with one engine out and was able to do the other engine with it in. I used SS hex head bolts and washers. In hindsight I think SS carriage bolts would have made a better finished presentation. My buddy with 1990 bravos had the same deal and he ordered the anode bolts off BAMs sight and went back with original.
If you can do it or not with the engines in really depends on how your engine bay is rigged. It would be hard in my panther to replace the bolts from the top.
JLAY
4
08-07-2007 01:58 PM
Attack
Fountain
1
03-24-2005 09:11 AM
patricklhill
10-17-2004 10:45 AM
MiamiVice
17
10-13-2004 12:30 AM
