No beeps when turning key!!! >
Old 09-03-2008 | 08:13 AM
Default No beeps when turning key!!!
Cruising across the lake, I lost all power. When trying to restart, I noticed there is no beep as there usually is when the ignition is turned. The starter will still go, just no ignition. Sounds like an electrical gremlin!
Its a 2000 454 Mag MPI, any suggestions of where to start?
Thanks in advance!
RYAN JOHANSEN
H2X BOSS is offline
Old 09-03-2008 | 08:57 AM
satisfactionII's Avatar
I have had that problem before. Frustrating it is. I found my problem with a loose connection on the alternator gauge. No beeeep, no start.
satisfactionII is offline
Old 09-03-2008 | 09:12 AM
MnFastBoat's Avatar
Charter Member#157
kill switch??
Some are set up that way, will allow you to turn over but no spark??
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 09-03-2008 | 02:30 PM
WHOSNEXT's Avatar
Originally Posted by MnFastBoat
kill switch??
thats what happend to mine...broken wire behind switch.
WHOSNEXT is offline
Old 09-03-2008 | 03:30 PM
I recently had a starter installed with the same problem/ no power/ no beep. Turns out the ground wire was loose (interpret: probably not hooked up).
Jupiter Sunsation is offline
Old 09-04-2008 | 11:00 AM
Biligemouth's Avatar
Loose wire somewhere. Buddy had oneon a Baja junk going to a fuse block work loose...exact same symptom as you.
Biligemouth is offline
Old 09-04-2008 | 11:11 AM
kill switch??
been there done that check first
eliminatethis is offline
36spectre
9
08-21-2007 09:26 PM
Dave98
Powerquest
7
08-08-2005 08:11 AM
BGIII
Prop Talk
8
08-05-2005 07:40 AM
dukenrock
06-28-2005 08:56 AM
duunoit
3
05-02-2005 10:30 AM
