20P Enertia Prop 3 blade RH
This prop is pretty much brand new. I switched from a Mirage 19 plus and I gained 2 mph top end but it did not do what I needed for tubing. I have the Mercury box that it came in and the XR hub. It is on a Bravo I but there are other applications that will work as well. This prop costs a little over $500 online new. I would like to trade for a comparable 4 blade that will give a lot of transom lift. I want to be able to go slower on plane for tubing.
It says on the box :
For Alpha and Bravo drives from 135 - 275 HP
Part # is 48-899000A46
13 3/4 diameter
Made with X-7 allow
www.bowkersfiberglass.com
13 3/4 diameter
Made with X-7 allow
