temp gauge
Old 09-05-2008 | 03:35 PM
Default temp gauge
1999 Baja 252, and out of no where the temp gauge is only reading 110. I thought the gauge was wrong or broke, but if you run it hard,m then you can see it move to about 130 MAX... I think the thermostate is stuck open, but 110-130 is VERY cold... Ideas??
mittens is offline
Old 09-05-2008 | 03:45 PM
First thing to check is the guage and sender and make sure they are matched.
Griff is offline
Old 09-06-2008 | 12:53 PM
baja bailey's Avatar
I had same problem before and it turned out sand had the themostat stuck open.
baja bailey is offline
Old 09-07-2008 | 08:44 AM
was it running that COLD??
mittens is offline
Old 09-22-2008 | 02:22 PM
Ok, so took it our again, and everything worked normal. so for three weeks the thermostat was stuck open, andnow it works again???? guessing i should replace. any thoughts?
mittens is offline
Old 09-23-2008 | 07:42 AM
Yes
masi242
10-23-2008 10:38 AM
boatfreak
Drives and Lower Units
1
09-10-2008 10:41 AM
Intruder88
07-20-2008 05:56 PM
97BossHammer
8
03-25-2003 02:50 PM
