Advantages of a dually
Old 09-05-2008 | 03:59 PM
Default Advantages of a dually
What is the advantage of having a dually over a srw truck. I have a 29 Fountain (9,500 - 10,000lbs best real world guest with gas, trailer, etc) and a 3500 srw diesel would be more then enough to tow it realistically, but what are the real world advantages of the DRW?
Racerngr1 is offline
Old 09-05-2008 | 04:05 PM
For that boat, no advantage.
For something bigger the DRW will just keep the road sway down and puts more rubber on the ground in the event of a braking/handling issue.
Jupiter Sunsation is offline
Old 09-05-2008 | 05:29 PM
t500hps's Avatar
21 and 42 footers
Had a 31 Formula and a 3/4 ton truck......did OK but not great. Bought a 38 Formula. Towing down the highway anytime anything passed by the truck would sway all over the place. I'd get to the ramp and already be sweating from the drive. Bought a dually.....75 on cruise control and don't worry about tractor trailers passing me or me passing them now. Pulling power basically the same, sway GREATLY improved, "OH CHIT" stopping ability also greatly improved.
t500hps is offline
Old 09-05-2008 | 05:49 PM
As stated, having the training wheels is all about stability.
I'll hook up to just about anything, towed our 5th wheel at about 12,500 12 feet tall, absolutely no issues.
The boat is probably weighing in around 14K on the trailer totally full, pulls like a dream.
If I had to use it as a daily driver it would get old in a hurry though, parking in regular lots can be a pain, mainly because I like to stay clear of all the idiots.
PJDiesel is offline
Old 09-05-2008 | 06:05 PM
jeff32's Avatar
day and nights with big loads as stated, you sure don't need this big of a truck, unless...
thinking bigger soon?
jeff32 is offline
Old 09-05-2008 | 06:20 PM
I just bought this boat in March and am not as much of a pimp as some people on here, so I think I will stay with my boat for a little while longer.
Old 09-05-2008 | 08:23 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
SRW will be fine. Congrats on the new boat!
mcraymond3 is offline
Old 09-06-2008 | 12:35 AM
Originally Posted by PJDiesel
...If I had to use it as a daily driver it would get old in a hurry though, parking in regular lots can be a pain, mainly because I like to stay clear of all the idiots.
My 2006 Dodge dually quad cab is my daily driver and it drives and turns really well. The only issues I have are the 6speed manual which is a pain in town, and the long wheelbase which can hit curbs on turns if I'm not careful. I make right turns into the left lane whenever possible.
For parking lots around malls I park way away from everyone and take two spaces, hell four if I can. I don't mine the walk, good for me. For the small lots I just try to make the best of it with one spot if I absolutely HAVE to.
Hot Knots is offline
Old 09-06-2008 | 04:49 AM
hillbilly24's Avatar
I drove a long bed crew cab dually for years as a daily driver and you honestly get used to it quick, there isn't a spot you can't get into as long as you back in. Just get your mirrors set up right and get used to using them instead of craning your neck around and it is easy money.
hillbilly24 is offline
Old 09-06-2008 | 06:50 AM
GO4BROKE's Avatar
Besides more rubber on the ground you usually get a bigger rear end, brakes, springs. I'll never own a srw truck again. I've had duallies since 2000. They really don't cost much more. Buy a big truck now, you won't have to upgrade later.
[img][/img]
GO4BROKE is offline
