Aligning trailer axles?
Old 09-06-2008 | 05:16 PM
Default Aligning trailer axles?
I have an older triple axle trailer. When towing, it dog tracks slightly. I can also see in my mirror that the axles are out of line ever so slightly. What is the procedure to align them? Thanks
MILD THUNDER is offline
Old 09-07-2008 | 09:41 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I don't know if there is a "proper" way to do it. But, I did it a couple years ago with a laser level and a tape measure.
I had the boat off, and the trailer suspended on jack stands. I placed the level against the front of the brake rotors, and used the tape measure to to adjust the axles for equal measurements from the I-beam at all four corners.
It worked great, and about a year after I did so, the boat and trailer made a successful trip from VA to MT with no issues. Good luck.
Sydwayz is offline
Old 09-07-2008 | 01:04 PM
Registered User
Measure from the tip of the ball receiver to the tips of the axle stups and square. Then set subsequent axles paralel to the first one.
Chris Sunkin is offline
J.B. Marshall
04-12-2006 05:20 AM
MnFastBoat
6
08-02-2004 10:23 PM
MnFastBoat
6
04-18-2004 09:45 PM
Tantrum
03-16-2004 10:34 AM
euby
12
07-22-2003 08:42 AM
