2008 F-450 Project
Ok, so I sold the Peterbilt and now I am left with only one truck that looks like every other white dually on the road. I have driven it totally stock for a year and a half now, so I figured that it was time for a change!
Like most of you, I like the challenge of a good project, so what the hell, here we go. I set out with the goal to make a truck that will stand out in the crowd on the street, go anywhere I want to go on the beach or at the farm and still be a functional tow rig. Well, here is what we have completed so far.
We installed a Pro Comp 6" suspension, but had to go to Kelderman for the steering components since it is a 450. We followed that with a set of 22" wheels wrapped in 37" Toyo mud terrains. Next to go was the factory air box under the hood and the factory exhaust. This is what we had at the end of the work day on Friday.
The new rear tires stick out a bit
so we will be installing wider, replacement rear fenders from Street Scene when the truck goes to the body shop. These fenders will look exactly like the factory fenders, just a little wider. Needless to say, we will be installing mud flaps as well.
The tires look tight, but they will fit in the wheel wells. We actually installed them for a sneak preview before adding the lift and they fit. I like the look of the new exhaust tip compared to the factory setup. Without the regen cycle and the DPF, the exhaust will stay nice and cool too. We also installed a larger intercooler to help keep the EGTs in check.
so we will be installing wider, replacement rear fenders from Street Scene when the truck goes to the body shop. These fenders will look exactly like the factory fenders, just a little wider. Needless to say, we will be installing mud flaps as well.The tires look tight, but they will fit in the wheel wells. We actually installed them for a sneak preview before adding the lift and they fit. I like the look of the new exhaust tip compared to the factory setup. Without the regen cycle and the DPF, the exhaust will stay nice and cool too. We also installed a larger intercooler to help keep the EGTs in check.
Saturday was spent installing items that are out of sight. We installed a set of Firestone air bags in the rear with a compressor and wireless remote. This will keep the rear from sagging while towing. We also installed a second compressor and tank for on board air (air tools/tire inflation/etc) and for the Stuttertone air horns (fire truck sound). For those familiar with fire apparatus, we are using a pedal mounted inside the footwell by the hood release for the horns. A tap of the toe is all it'll take!
That is sweet I have everything but the wheels to do mine. Almost the same setup. I am going with the fabtech they just came out with a kit with all the front end parts. What are you having to pay for the fenders I was checking into that as well. Seen chrome wheel had some for about $900. Looking good.
Today was spent rough fitting the bumpers. We got both hung, but still have some fitting to do tomorrow. We will be cutting holes in the rear bumper where the logos are now to flush mount reverse lights. We also have to drill holes tomorrow to mount the factory reverse sensors. Since we removed the spare tire and components, we will be using the hole meant for the spare tire crank to install a quick disconnect fitting for the on board air system. This will allow easy access when you need air for something.
Up front we need to finish fitting the bumper, mount the lights in the holes and also pre fit the winch (Warn 16.5). Once everything is how we want it, the bumpers will be removed and sent to the body shop to be painted white to match the truck. Oh yea, the grill shell will be painted white as well.
We still have to fit the ram air hood, install the power inverter, install the rear fuel tank and install the water tank and pump in the bed. We're getting there one step at a time. I'll keep you posted.
I called Chrome Wheels twice when I was putting together the parts list and I got the impression that I was bothering them, so I ordered everything from other places. They were just real short with me on the phone. Maybe I got them on a couple of bad days.
Post some pics of yours if you get a chance. It's all in the details like that and I would love to see it as you build it.
Will, are you getting the fenders that have the vents built into the front of them?
http://www.stylintrucks.com/parts.as...tfamilyid=6060
I like the looks of the vents on them.
I assume you are going to white out the mirrors and the door handles too. A nice set of clear clearance lights will also look sharp.
I look forward to seeing the finished truck.
