Exhaust silencers >
Exhaust silencers
Exhaust silencers
Old 03-06-2002 | 06:21 AM
Ghia's Avatar
Question Exhaust silencers
I have a 2000 Stingray 230SX with a 454 Mag EFI, with exhaust silencers (the tips have baffles that swirl the water and exhaust for muffling. Not sure of the specific name of this silencer.) Anyway, I was told that removing these tips in favor for an open exhaust would net a 2-3 MPH increase of my 71MPH top end. I personally don't think the tips are that restrictive, but I want to ask first. Will it be worth the trouble and cost to change to open tips?
Ghia is offline
Old 03-06-2002 | 09:39 AM
BajaBoss252's Avatar
Ghia,
I have the same question about my Baja. It has the Corsa Quick and Quiet II system. I wanted to just pull the internals out rather than switching tips entirely. I asked this question on another board also and one guy there said not to pull out the baffles as this might allow water to enter the engine. I have external rubber flappers on my tips but I'm not sure if that is enough to keep water out when coming off of plane. I guess my question, along the same lines as yours would be, do the baffles really do all that much in keeping the water out or can I just yank them out...
Ted
BajaBoss252 is offline
Old 03-06-2002 | 09:41 AM
Wally's Avatar
Were doomed!
2-3MPH???? from removing the exhaust tips?? No way! Its gonna sound alot better (to me anyway! ) but you wont see anything out of doing that mod. you may get a few x-tra Hp from the less restriction but not enough to make a change in speed. Especially if you are allready in the 70's. It takes more hp to go faster the higher the speed gets.
-Wally
Wally is offline
Old 03-06-2002 | 11:38 AM
Intolerant1
If you are talking about baffles that look like big cork screws welded inside the tips then you might be in luck. I had these in my Liberator and removed them using a sawzall with a long carbide blade to reach in and cut the welds. I picked up about 5 mph and after changing the intake ,rejetting and going up a prop size gained eight mph. If they are the corkscrew type, they are very resritictive.
This was on my boat and I agree that you might not see much on a faster boat such as yours. What to you have to lose though?
mats
4
06-15-2006 08:30 PM
Sydwayz
08-24-2005 11:11 PM
502KC
Fountain
5
08-03-2003 09:32 AM
502KC
3
07-09-2003 10:07 AM
dean campbell
5
04-04-2003 03:54 PM
