holley?
Old 09-15-2008 | 06:08 PM
Default holley?
how can i tell what kind of holley i have so i can get a rebuild kit the only numbers i see are p-32 on the side of the main body and 9108 onthe metering blocks also i have edlebrock rpm air gap intakes on my motors now does anyone know any better performing intakes for the 502's with world 345cc heads bored 60 over
thanks for any help
toggle throttle is offline
Old 09-18-2008 | 03:45 PM
In the top right hand corner of the air horn it should say. (List and then a four digit # if it is regular production holley). This is the number you use to get the rebuild kits.
45SS is offline
Old 09-18-2008 | 03:52 PM
jayhawk261's Avatar
If it has a choke tower, it should be as described by 45SS. If it doesn't have a choke tower, it should be on the main body behind the throttle linkage. If someone has cut off the choke tower, then you may have to call Holley!
jayhawk261 is offline
Old 09-18-2008 | 03:58 PM
yeah, like post number two said. sometimes there are five digits like this 0-80443
that is a 850 cfm elec. choke, mech. secondary marine carb
there may also be a - after the four or five digits. hope this helps
panicrev is offline
BAD-HABIT
13
06-06-2004 07:29 PM
crmax
3
01-27-2004 04:28 PM
formula31
3
06-07-2003 07:41 PM
BAD-HABIT
4
05-23-2003 08:45 PM
Pantera24
1
05-20-2003 12:01 AM
