Differance in a #4 a #3??? >
Old 09-16-2008 | 10:56 AM
SKRAMER's Avatar
Default Differance in a #4 a #3???
Whats the differance in a speedmaster#4 to a 3 and 3a?? Thanks Scott
SKRAMER is offline
Old 09-16-2008 | 12:23 PM
A 4 is a shorty version of a 3. A 3A is stronger version of the 3 and handle more HP.
Griff is offline
Old 09-16-2008 | 12:37 PM
SKRAMER's Avatar
Is a 4 weaker then a 3a????
SKRAMER is offline
Old 09-16-2008 | 04:03 PM
PatriYacht's Avatar
If it is a small shaft 4. A large shaft 4 is smilar to a 5. Alot of parts do not interchange however. 10x has #4's, maybe contact him.
PatriYacht is offline
Old 09-17-2008 | 01:31 AM
As far as I know, the 4 is a shorty 3 and the 5 is shorty 3A. I didn't know they had different shafts for the 4's.
Based on that, the 4 is a little weaker. I think they are still rated about 700hp.
Griff is offline
Old 09-17-2008 | 06:00 AM
Biggus's Avatar
Also, the Speedy IV is 6" shorter than a III
Biggus is offline
Old 09-17-2008 | 06:21 AM
SKRAMER's Avatar
Is there a way to know what shaft it has without opening the drive up???
SKRAMER is offline
Old 09-17-2008 | 06:49 AM
CIG3's Avatar
A #5 will havea large prop shaft. Be careful because you can get a 4a with a large shaf also. If I remember there is a diffenence in lower case thickness for the beefed up shafts in the #5 stuff.
CIG3 is offline
Old 09-17-2008 | 12:18 PM
Small and big shaft size refer to the prop shaft. Props come in 2 sizes for the SSM.
Small shaft (SSM II, III, and some IV) are 19 spline. Big shaft (SSM IIIa, V, VI and some iVs) have 26 spline. The big shaft IV will be stronger.
rdoactive is offline
Old 09-20-2008 | 12:52 AM
what about the difference in length of a #II to a #III??
MILD THUNDER is offline
