Oil temp to hi, 540 w/blower >
Old 09-17-2008 | 06:40 PM
Default Oil temp to hi, 540 w/blower
Oil temp way to high!
Temp sensor - OK
Oil pressure - OK
Where should I start to look?
Thanks for any input!
Hydrolift is offline
Old 09-17-2008 | 07:11 PM
What do you think is to high ??????
Jeff P31 is offline
Old 09-18-2008 | 03:29 PM
Strip Poker 388's Avatar
Rob
water flow thru cooler? Does the oil pressure drop at idle when it hot,mine says around 30 at 200,after a hard run.
My Chevelle sbc would be around 20
Have ya change anything ? same application just started running hotter?
Strip Poker 388 is offline
Old 09-19-2008 | 01:44 AM
What engine/HP???
Whats the oil temp????
if its too high, then you need a bigger cooler or have a flow problem.
Griff is offline
Old 09-26-2008 | 07:31 PM
Thanks for your replay, havent had time to work at it before yesterday. Oil lines were old and decided to change them. Looks like it solved the problem.
BTW:
Oil temp 275+ and rising fast
Engine 750+ HP
Thanks again, and have a nice weekend.
kidapache
Swap Shop
0
08-26-2008 12:53 AM
Velocity Vector
0
04-03-2008 01:45 PM
H2X BOSS
2
05-13-2007 11:58 AM
slobaja
Baja
3
02-05-2006 03:49 PM
VelocityMark
2
06-24-2003 02:19 PM
