Bottom pad pix >
Bottom pad pix
Bottom pad pix
Old 09-20-2008 | 01:56 PM
Default Bottom pad pix
Here is a few, if you need more I will post them.
Attached Thumbnails Bottom pad pix-prom-247.jpg   Bottom pad pix-prom-249.jpg   Bottom pad pix-prom-251.jpg
Andy is offline
Old 09-20-2008 | 03:46 PM
Do you have enough stuff hanging down?
Velocity Tom is offline
Old 09-20-2008 | 04:18 PM
I call those brakes.
MOBILEMERCMAN is offline
Old 09-20-2008 | 06:41 PM
Velocity Vector's Avatar
Crazy Energy
32 pad on top 30 pad on bottpm
Velocity Vector is offline
Old 09-20-2008 | 08:45 PM
FlashPRace's Avatar
260 pad is like the pic of the 30 pad.
Now, I was told the 260 and 280 pads are the same length.
Is that true?
How much longer is the 30 pad?
FlashPRace is offline
Old 09-20-2008 | 09:18 PM
Andy, what is the water pic up for on the both sides of the pad! Seems like that would keep the props from getting "clean" water???? I'm a rookie, so don't hold that question against me if it is a stupid one!!!!!
DKerns is offline
Old 09-20-2008 | 09:50 PM
1HYPER1's Avatar
Looks to me to be the pickups for the intercoolers.
1HYPER1 is offline
Old 09-21-2008 | 06:57 AM
Crazy Energy
I can't see any difference in the 30' pad vs 32' pad. ? except the 32 looks faster
Old 09-21-2008 | 07:10 AM
1HYPER1's Avatar
The pads are the same width but the pad on the 320 is about as long as the pad on a 22 f00t boat where as for the pad on the 30,it is the correct length for the boat because it was designed and built to be a 30 foot boat.The 320 is a boat that was built out of the mold for the 41 and they just basically made a smaller boat out of it and that is why the running surface on a 320 is so short and there for it is a boat that is very difficult to keep on the pad.The more HP the boat has the better it will stay on the pad in a twin engine set up as for the 320 with a single,Kurt says that it rides at all speeds pretty goog but I will let him comment on it.
1HYPER1 is offline
Old 09-21-2008 | 07:19 AM
Crazy Energy
Seems like at speed, we are only running on about 3' 4' of pad anyway. So I don't see a longer pad doing anything if it isn't in the water.?
