ITS Extention Box 5" Spacer
Want more set back from your ITS? Now you can!! Five inch adjustable (two inches) Billit Spacer improves acceleration,more stable at top speed,better angle of attack while spanning the waves. Our test boat normally ran 96 MPH with the standard ITS Sterndrive. After we installed the 5" set back plate, increased pitch, our test boat ran 102MPH! 5 MPH FASTER. Kit includes all hardware,CALL 302-521-0123
Diamond Performance
Diamond Performance
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
Weight?
Large enough to cover stock footprint?
Uses stock inside transom plate?
Studs, S.S. or ARP Stainless?
Input shaft; 5 inches longer? how? Billet, welded (hope not) etc.
Does it come painted?
Does the stock unit use the O-Ring too? Do you include 2?
Pitch change; How much, how many blades?
Cost?
Thanks, Very interesting, How did you come up with 5 inches?
Cost?
Large enough to cover stock footprint? - YES
Uses stock inside transom plate? - YES
Studs, S.S. or ARP Stainless? - Stainless
Input shaft; 5 inches longer? how? Billet, welded. - Shaft is Stainless, Slides over your Splind Bravo Shaft
Does it come painted? - It is Billet, Powercoated
How did you come up with 5 inches? - The Merc ITS is seven inches, Most Boxes are 12" or 13"inches so we made it 5" inches.
[email protected]
302-521-0123
[email protected]
302-521-0123
Don't know how much it weighs, never had it on a scale. It does come with O-Rings.
Pitch jump depends on how high you set the Box, The Box can adjust up or down 2"inches.
Cost is $4850.00
Cost is $4850.00
[email protected]
302-521-0123
[email protected]
302-521-0123
