Block needed 9.800 ASAP >
Old 09-25-2008 | 11:43 AM
10x's Avatar
10x
10x
Default Block needed 9.800 ASAP
I need a std. deck (9.800) block right away. Preferrably a Merlin, Dart or even a Bow Tie. It needs to be a 4.500 bore or larger. The actual bore size I need is 4.602. So anything smaller than that will work. Also prefferably something close to Chicago for quick shipping.
If you have one that will work for me, call me at 708-870-2572.......ASAP
Thanks,..... Frank
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 09-25-2008 | 01:53 PM
Nordicflame's Avatar
http://www.offshoreonly.com/forums/showthread.php?t=196000
Nordicflame is offline
Old 09-25-2008 | 05:42 PM
TomFTM's Avatar
I have a customer who has 2 merlin 3 4.530 brand new 9.8 blocks.
We also have a merlin pro block that is currently a 4.560 and needs to go further to clean up. fresh water cooled block. pm me if interested
TomFTM is offline
Old 09-25-2008 | 07:55 PM
I have a Merlin block that is completely machined and ready to build in the swap section. Bore is 4.500. Make a decent offer and it can be on its way to you tomorrow.
Frank
thedonz is offline
Old 10-01-2008 | 09:04 AM
10x's Avatar
10x
10x
Actually, the current block is a Merlin, and has 5 or 6 sleeves, because of cracks that come from the head bolt holes to the cylinder bores. He wants to stay away from the Merlins, because when you go to a bore size of 4.600 or larger, they seem to all start having this problem. He wants to wait for a Dart or possibly a Bow Tie block. We need a 4.600 bore size to finish to 4.602, and the .904 lifter bore holes too if possible. That can always be done when the block is being finish honed.
Thanks alot for all the help.
[email protected]
10x is offline
Old 10-02-2008 | 01:46 PM
TomFTM's Avatar
all of the merlins that I have are 904 lifter bores.
TomFTM is offline
Old 10-02-2008 | 11:34 PM
10x's Avatar
10x
10x
Thanks Tom. I will see my friend at the strip this weekend. Send me a PM with the price of the 4.560 block, and if he is interested in it, I'll let you know ASAP.
Frank
[email protected]
10x is offline
Old 10-03-2008 | 01:57 PM
$1,500 for my Merlin with all the machining done, ready to build.
thedonz is offline
Old 10-17-2008 | 12:47 PM
Sa Newbie I am not sure of all the technical specs but I have a 454 425 HP HO mercruiser block that I just took out of my Checkmate.
I am in Chicago so I could figure a way to hand it off if it works for you.
the vig is offline
Old 10-20-2008 | 01:14 PM
Smitty's Avatar
I,ve got a Gen 6 that the bore is currently 4.530. It is all cleaned up and ready for sale. PM me for info.
Smitty
I also have the crank and stock rods for this block if anyone needs stock stuff.
Smitty is offline
