Great Lakes Diesel International Marine Engine Builder
GREAT LAKES DIESEL – The world’s only Hi-Performance Diesel Engine company has stepped up production of stock Series 3400 Caterpillar Engines (3406 B/C & E Models and C-15, C16 & C18) to help fill the void left by Caterpillar. These engines are constructed using Original Equipment Manufacturer (OEM) components. GREAT LAKES DIESEL uses the same technology which uses a matched system concept that helped develop their famous Blueprinted Hi-Performance engine which is balanced and machined for a precision fit. These concepts have been integrated into the 3406 stock engines which result in Increased Horsepower and Higher Fuel Economy. These High Quality Custom Engines are 16 Liters and produce 600HP and can be configured for On-Highway truck market, Marine and Heavy Equipment applications at a low cost to the end user.
We use state of the art manufacturing techniques designed to provide optimum performance, durability and horsepower with fuel economy in mind. An example of some of the components used in building your engine is listed below: ECM Performance software. Water jacketed exhaust and turbocharger.
We can build a matched set of engines ready to go for anywhere up to 1000hp, Dyno-tested, break-in period, crated and ready to install!
We know we can help with the Engine cost, Performance and fuel efficiency in your vessel We would love to discuss your options with you.
Please Contact Mindie at 800-930-6088 with any questions and to get on the water with "The Power You Can Feel From Behind The Wheel" .
Email: [email protected]
Website: www.greatlakesdieselengines.net
MySpace: www.myspace.com/greatlakesamericandiesel
Well let's see...Cummins, Yanmar, MTU, Seatek, Volvo-Penta...I could go on, but why? Lots of performance diesels out there, but few can be used in our boats unless they are at least 40' monohulls. Performance boats that run over 60mph were not designed for heavy diesels.
Cat motors are very heavy too. Your C18 weighs 3750lbs if I'm not mistaken, and the only performance boat I know of that uses them is the 51' Bladerunner trimaran, which weighs right at 28,000lbs and runs almost 80(not bad for such a heavy boat).
How bout Caterpillar develop a high performance diesel making at least 700hp and weighing not more than 1500lbs, gears and all.
And please explain about "fill the void left by Caterpillar".
OSO News
Offshoreonly Industry News
0
06-19-2007 11:03 AM
