Hyd roller cams for sale... >
Old 03-08-2002 | 10:50 AM
KAAMA's Avatar
Default Hyd roller cams for sale...
Ultradyne billet w/cast iron gears, 296/296, 244*/244* @ .050 duration, .601"/.601" lift on 112* lobe seperation. These cams made 699hp @5750rpm and 704 ft# of torque @4800rpm on Tom Earhart's dyno (SAE standard corrected data).
One cam is still new and in the box and the other has dyno time on it only. $245 each Mark 616-291-7932
KAAMA is offline
Old 03-08-2002 | 11:24 AM
Crazyhorse's Avatar
Are these 3/4 or full race cams?
Crazyhorse is offline
Old 03-08-2002 | 11:45 AM
what size motors, heads, comp and intake. thanks. i am iterested.
cigarette39 is offline
Old 03-08-2002 | 11:54 AM
KAAMA's Avatar
540cubic inch, ported Dart Pro-1 310cc aluminum heads, 9.5:1 cr, with Dart open plenum intakes
KAAMA is offline
Old 03-08-2002 | 12:05 PM
KAAMA why are you selling them? I thought that your motors were ready to go in the boat? What's the plan now?
check300 is offline
Old 03-08-2002 | 12:07 PM
do you think they will make the same power in my 580ci engines with 345cc world heads minor ported 9.5 comp and merlin intake. can you post the cam timing specs please so i can run in my desktop dyno thanks.
Old 03-08-2002 | 07:40 PM
Blueman
cig 39 did those numbers help you any that i put on your post?
Old 03-08-2002 | 10:06 PM
KCHOTBOAT's Avatar
Charter Member #737
You get tired of hearing that one also.
KCHOTBOAT is offline
Old 03-08-2002 | 11:05 PM
KAAMA's Avatar
Cig39,
I would love to sell you the cams and I could be wrong, but in all honesty I think they'd be a little on the small side for the 580 cubic inch engines that you're planing on running. For a hydraulic roller cam, you're going need something with a little more duration than 244* in my opinion...something more like the high 240's on the intake and mid 250's on the exhaust perhaps. Being that my cams are too small for your cube size, I wouldn't want you to be disappointed on the power---but I do appreciate your inquirey.
Thanks, Mark
KAAMA is offline
Old 03-08-2002 | 11:12 PM
KAAMA's Avatar
Hey Crazy,
3/4 race cam huh?....been a looooong time since I've heard that term! Sounds like me 25 years ago when I was a youngin calling up the cam companies. Got a good laugh out of it though!
KAAMA is offline
