Just getting my rebuilt motor back, engine oil thoughts.....
The builder of my motor doesn't want me to use the Mobil 15W-15 that i was using. He says it's not the same quality it once was. He isn't trying to sell me on the oil he uses but did recommend Brad Penn racing 20-50. He also said he liked the amsoil 20-50 oil. Any thoughts?
Right now i have break in oil that will be coming out shortly.
Do a search on Hydorcruiser posts. Mobil 1 15-50 did change formulations from Red to Gold then to Silver cap. If I read things right Mobil 1 15-50 Silver cap is a good buy considering you can get 5 qts. at Wally World for 22 bucks.
I know, i have been running the mobil one silver cap. Didn't think i was having any issues till this. Also found out my oil temp was never making it over 130 degrees..........
I having the oil thermostat installed that CPP sells. Should fix that problem.
Cloud,
I am not going to make an oil recommendation other than ..... if the builder is warrantying the engine, I would darn sure use what he says to
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
Brad Penn is what alot of the drag racers use, as well as what 4 engine builders that I know recommend.
