? On Triple's Prop Rotation >
Old 10-10-2008 | 04:18 AM
cig1988's Avatar
Default ? On Triple's Prop Rotation
I recently saw a 50' Scarab with triple Yanmar's into TRS drives. The owner claims the boat will not exceed 30 mph. I was thinking "what if" the wrong rotation would be the culprit ?
cig1988 is offline
Old 10-10-2008 | 12:35 PM
Not enough info.
More than likely, totally wrong props. Rotation alone as the problem is not likely.
Griff is offline
Old 10-11-2008 | 04:24 AM
cig1988's Avatar
Which way are the props supposed to spin on port, starboard and center? In other words lets say the outer drives spin in...which way should the center drive spin?
cig1988 is offline
Old 10-11-2008 | 11:34 AM
When I had my triple, I had two props spinning right, and one spinning left.
I would think the props are wrong on that scarab.
GS42fun is offline
Old 10-13-2008 | 03:51 AM
cig1988's Avatar
Which two props were spinning right?
cig1988 is offline
Old 10-13-2008 | 08:17 AM
On mine the center and the starboard were spinning right and the port was spinning left.
I rember seeing an article on a big diesel boat years ago. They couldn't get it to perform very well. They started to expirement with props, and it really woke it up.
I think props probably is the problem with that boat, but I think you would need to talk with a prop expert to know for sure.
With a little more information you could use a prop slip formula to see how the current props are performing. That would help get you started in the right direction.
GS42fun is offline
Old 10-14-2008 | 05:01 AM
cig1988's Avatar
Thanks GS
cig1988 is offline
markku4444
Prop Talk
1
01-15-2008 06:43 PM
Helmwurst
Donzi
14
08-13-2007 10:33 PM
barron
Fountain
12
10-11-2006 08:14 AM
Notched_Baja
15
03-02-2004 08:27 PM
boatinbill
07-26-2002 09:58 AM
