Where can I research oxygen systems?
I cant find anything online about oxygen systems in raceboats. Does anyone have a dealers website that I can browse?
The only kits i can find are the portable emergency air systems that divers use..
are the oxygen canisters mounted to the boat or to the driver?
full time air is rigged up pretty much the same way, you just have a full time mask, think fighter pilot.
out of morbid curiousity, how long can the air last on a tank that size with two regulators? Looks like only minutes!
and what happens if you get knocked out and have part-time air? and a lifejacket?
if you get knocked out without full time air (and you are upside down) you are hoping your partner didnt and finds your regulator for you, or that your canopy doesn't fill that fast. and usually, if there was no failure, they take a while to get that much water in them.
you have to use canopy jackets, designed to let you get out then inflate it. inflating your jacket while you are still in the cockpit or wearing the wrong style would be a very poor choice.
So a lifeline style jacket wouldnt work? I assume you have to use the auto-inflate style suspender jackets.. What about when you're running in a poker run and theres no helos or safety divers, what setup do you use then?
