Surge brakes not working.
Old 10-14-2008 | 08:36 AM
DMAX's Avatar
Default Surge brakes not working.
Four year old trailer with four wheel surge disc not working at all. Not even when manualy put into Brakes on Dont tow setting. The rese. is full, lines look good. Mostly fresh water dunked. What could it be. Thanks.
DMAX is offline
Old 10-14-2008 | 09:03 AM
Dock Holiday's Avatar
Charter Member #34
I would try and bleed them first and that will tell you if there is any air in the lines plus prove whether or not the system has any pressure.
If all is good there I would look at the brakes on the hubs for problems but unlikely that all four are bad.
Good luck
Dock Holiday is offline
Old 10-14-2008 | 09:20 AM
DMAX's Avatar
Thanks I'll give it a try.
DMAX is offline
Old 10-14-2008 | 12:26 PM
Master cylinder might be bad. They are about $100.
Griff is offline
Old 10-14-2008 | 02:41 PM
Knot 4 Me's Avatar
I had a lockout solenoid go bad and cause the same symptoms. Another thing to check if everything else pans out.
Knot 4 Me is offline
Old 10-14-2008 | 04:05 PM
IM4A2Z's Avatar
Ditto - I had a neighbor at the lake with exactly the same problem on an almost new trailer.
IM4A2Z is offline
Old 10-14-2008 | 06:49 PM
LV's Avatar
LV
throw some electric brakes on and forget about it, you wont be sorry for the extra jack you spend.
LV is offline
augie58
6
04-07-2008 10:01 AM
mnmstoy
0
05-18-2007 01:25 PM
aquatictherapy
6
08-23-2006 02:50 PM
WETTE VETTE
7
08-29-2005 08:36 AM
KN
02-15-2002 09:58 AM
