Merc 502 Oil Cooler, Rear Mounting >
Old 10-14-2008 | 02:45 PM
CigDaze's Avatar
Default Merc 502 Oil Cooler, Rear Mounting
I'm told I need one of these. It's the rear mount one, above the bell housing (not the low side mount). Anyone have a P/N or source. Thanks.
CigDaze is offline
Old 10-14-2008 | 02:55 PM
axapowell's Avatar
Where To
I've got the whole set-up for sale!
Dave
axapowell is offline
Old 10-14-2008 | 02:58 PM
I have a aftermarket one thats 17" long oil only(no p/s) 1 1/4 hose that I'm not using any more, email me if you are interested @ [email protected]
ezstriper is offline
Old 10-14-2008 | 03:01 PM
axapowell's Avatar
Where To
http://www.offshoreonly.com/forums/s...d.php?t=195086
Factory HP500 New lines and brackets. Follow the link!
PM me with questions.
Dave
Old 10-14-2008 | 03:07 PM
CigDaze's Avatar
Thanks guys!
ezstriper, I very much appreciate it, but I'm looking for a Merc. unit. Thanks anyway.
axapowell, PM sent.
CigDaze is offline
Old 10-14-2008 | 05:13 PM
axapowell's Avatar
Where To
Thanks Cig!!
Done Deal!
Dave
Old 10-14-2008 | 10:17 PM
Originally Posted by CigDaze
Thanks guys!
axapowell, PM sent.
Nick
I think I have the one you want. Does it also have the ps cooler and goes over the bellhousing? If so come and get or I can UPS it.
Steve
smiklos@sunprint is offline
Old 10-15-2008 | 06:36 AM
CigDaze's Avatar
Thanks Steve, but no P/S on this motor.
CigDaze is offline
Old 10-15-2008 | 06:54 AM
No problem
Steve
Old 10-15-2008 | 09:45 AM
One thing to keep in mind (this applies only to MPI's) is with a bellhousing oil cooler, your "Cool Fuel" setup is now plumbed after the oil cooler. If you are up North or offshore this probably will be no problem, but on inland lakes during the summer, heat-soaking/vapor lock has been a problem for me in the past. If you want the big bell housing cooler and the mpi then run a return line to the tank or you can do what I did and buy the "enhanced 502 mpi cooler" from Marty @ Lenco Coolers...this cooler goes in the stock location, has appx. 50% more cooling capacity, and has much less restrictive oil bungs. And its cheaper than you think. I just mounted mine last night and am now planning to install a 203* mocal t-stat on the filter pad...should end up pretty clean - I'll let every know. Thanks to Arcticfriends' oil thread for the inspiration. Take Care, Dave
liquidlounge is offline
ezstriper
0
06-18-2008 03:18 PM
slik22
3
02-23-2008 06:21 AM
TROUBLE MAKER
2
04-18-2006 07:31 AM
risenshine
4
11-01-2004 06:06 PM
SmallPP
2
02-25-2004 09:17 PM
