27 fever prop choice >
Old 10-14-2008 | 03:48 PM
Default 27 fever prop choice
can any body tell me what size prop my 2007 27 fever -496 mag ho it curantly has 24p bravo 1 lh 1.50 drive max speed 67 but rev limiter beeping its brains out would a 26p be to high
sam edwards is offline
Old 10-14-2008 | 05:06 PM
Yamaha 225's Avatar
If it is the stock propeller that came with the boat, it would not go in the rev limiter when new. The reason is most likely that the blades has been "laid back" (slightly less pitch). This has happened to me on two Fountain baots 29 & 35. I think 26" will be a bit heavy and give you a lot more time coming on plane. I suggest you get a prop guy to cup your blades at th right placees on the leading edge. Then you will have almost the same accelleration as before and the right rpms on top. It worked great for me. Also better bowlift and cruise speed on mid-throttle.
Do anyone know if 1,65:1 gear ratio with more pitch is a more common set-up on this package? It seems like Fountain has equipped alot of small engine boats with this. Can anyone explain the difference in te boats riding attitude with this change? Have always wondered about this.....
Yamaha 225 is offline
Old 10-14-2008 | 10:06 PM
fountainfevr's Avatar
Try a hydromotive prop 23 pitch
fountainfevr is offline
Old 10-15-2008 | 03:21 PM
Default hydromotive prop
is there any special model or type that i should hunt 4 ie 3 blade or 4
Old 10-15-2008 | 03:55 PM
Was your boat set up with right or left hand rotation?
Racerngr1 is offline
Old 10-15-2008 | 05:08 PM
Default drive rotation
l/h rotation
Old 10-15-2008 | 05:41 PM
hydromotive 23 4 blade left hand rot.
27Fountain is offline
Old 10-15-2008 | 07:09 PM
My `97 with the 500hp runs 74mph @ 5600 rpms, with a Bravo 1 24p L/H. Just bought a 26p Bravo 1, but haven`t had the time to compare?
Bomann is offline
Old 10-15-2008 | 07:28 PM
If I were you I would run a Hydromotive Quad 4 24 pitch. You can detune it if you need to a 23. The Q4 is pretty neutral as far as lifting is concerned, it's not a stern lifting prop, it's a very common prop on the Fountains. It's what I run on my 29 with a 500EFI. My .02!
Old 10-15-2008 | 10:29 PM
you want peformance ? get a labbed 26 Bravo from BBLades.A labbed 26 will turn more RPM than a 26 non labbed.
mcprodesign is offline
