Best way to winterize when you have low water pick-up on the drive? >
Old 10-19-2008 | 08:51 AM
Default Best way to winterize when you have low water pick-up on the drive?
I usually take my boat in for winterizing. This year I decided to start doing it myself but can't find a decent flush muff for the low water pick-up on my drive. I want something that sealed tight to the drive so I can draw the antifreeze from a 5 gallon bucket rigged with hose.
Should I just disconnect the hose from my sea strainer and attach my 5 gallon bucket there?
MacGyver is offline
Old 10-19-2008 | 10:28 AM
I bought a boot rite from merc that goes over the LWP. $75 but worth it so you dont have to screw around.
JRider is offline
Old 10-19-2008 | 10:40 AM
axapowell's Avatar
Where To
You can go right to the sea strainer. Just remember to blow air into the line that goes to the drive. Also dump some antifreeze into that line (to the drive) just in case. If you want a muff, I've got a brand new Merc one that I never used for sale! PM me if you are interested!
Dave
axapowell is offline
Old 10-19-2008 | 04:47 PM
Rubber maid tub.
UP_ROKTOY is offline
Old 10-19-2008 | 05:17 PM
Originally Posted by UP_ROKTOY
Rubber maid tub.
I already have a tub for a half barrel that the drive fits in. But I'd use way too much anti-freeze that way. Looking for a direct connect method to the drive low water pick-up.
MacGyver is offline
Old 10-19-2008 | 10:02 PM
also was wondering if we take the plug out of the block disconnect the 2 lines to sea pump and blow out. Tried to get my end torks out of my CMI exhaust but they would not come out. Are we safe if the pink stuff comes out of the exhaust we used 6 gallons per side? Also do peope leave the pink juice in all winter? Thanks in advance Jeff
satisfied1 is offline
Old 10-19-2008 | 10:44 PM
I dont know about that over here in the U.S. , but in germany we used to fog the carb and then pulled all the plugs out of the motor and pulled the hoses off.
In spring put the plugs back in and the hoses back on and run it.
(not the freeze plugs, the little drain plugs for the block) ?!
Worked all the time and it got damn cold there too.
I say around 10 below 0 Farenheit (-35 c.) at night.
DareDevil is offline
Old 10-20-2008 | 03:34 AM
careful if you are running thermostats, be sure engine is up to temp -- thermos are open. You might see anti freeze come out the tail pipes and still have 100% water in the block otherwise.
It is always good to pull the drain plugs from everywhere in order to allow flushing of any sand or crud that has gotten stuck in the water jackets over the year too.
delsol is offline
Old 10-20-2008 | 05:44 AM
Payton's Avatar
Charter Member #927
Put a T in the kine going to your strainer. Then run the line up to where you can get at it easily. hook up a 5 gal. bucket and you are good to go.You can get a fancy or as simple as you want to. Have a hose attachment permently installed or just cap the T and you are all set for next year.
You do need to warm the engine up before hooking the bucket up. Just have a garden hose on the fitting, when warm remove and hook up the bucket.
Payton is offline
Old 10-20-2008 | 06:03 AM
hp500efi's Avatar
Member #9
Good point,
When I help my friend winterize his (non heat exchange motors) we remove the t-stats, then pump in the anti freeze. Come Spring, re-install the t-stats. If the t-stats remain in the warm motor, never can trust if they stay open when pumping in cold anti-freeze. Better safe than sorry.
Member of the Liquid Jungle
hp500efi is offline
