what is the fuel consumption for 496 ho >
Old 10-19-2008 | 04:04 PM
Default what is the fuel consumption for 496 ho
hi guys
can somebody tell me the mpg over the rpm for a single 496 ho
thanks
tcm07 is offline
Old 10-19-2008 | 07:10 PM
yesrej's Avatar
not good...
yesrej is offline
Old 10-19-2008 | 08:30 PM
not sure but better then a 525
mikebrls is offline
Old 10-19-2008 | 08:43 PM
Wink
It's going to be totally dependant on the boat, prop selection and drive ratios, etc. I could not begin to guess here without a lot of input.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 10-19-2008 | 09:28 PM
t500hps's Avatar
21 and 42 footers
Most performance boats with twins will be between 1 mpg to 1.5 mpg. If fuel consumption is of any consideration.......buying a boat is not for you.
t500hps is offline
Old 10-19-2008 | 09:57 PM
MPG will vary depending on the boat and efficiency of the hull.
Merc has charts that will show the GPH(gallons per hour) at various rpms though. At WOT, a 496 HO is probably about 35gph.
Griff is offline
Old 10-20-2008 | 07:23 AM
Dave M's Avatar
Veteran: Navy
Exactly! I run my diacom software and record live data. I've determined that 3500 RPMs is my best bang for the buck. I'm burning around 14 GPH and running 55 MPH. That's nearly 4 MPG, not bad for a boat. Over many hours I average around 11 GPH. That's some idle, cruise, and WOT.
Dave M is offline
Old 10-20-2008 | 08:27 AM
vagrant's Avatar
Charter Member #37 /Moderator/Platinum Member
A friend of ours has a 41 Velocity we ran 178 nautical miles at a RPM 3200-3600 his average was about 1.6 mpg.
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
vagrant is offline
Old 10-20-2008 | 11:24 AM
Chris288's Avatar
AT WOT 5,100 I get 1mpg @ 70 mph so at WOT my 496HO burns 51.4 gph. MY best bang for the buck is ~ 3,500 also, I get about 3mpg.
Chris288 is offline
Old 10-20-2008 | 11:35 AM
Gladhe8er's Avatar
Sounds high. My 525 burns 42 GPH at WOT according to Smartcraft.
Gladhe8er is offline
