Help W/ Set-up >
Help W/ Set-up
Help W/ Set-up
Old 10-20-2008 | 01:57 PM
Default Help W/ Set-up
So I'm building a 540 blower motor and have been kicking around the idea of how all of this will or won't work together.
Closed cooling system.
I also have a Superchiller how does that get plummed? From the circulation pump to the Super Chiller then to the Oil cooler, then Exhaust?
Dry sump oil system and a Engine pre-lube system. How will these two work together and how are they normaly installed (what order)?
The Blower is a Vortech unit (5 PSI), and the engine has a custom EFI system.
x7734x is offline
Old 10-20-2008 | 04:12 PM
The chiller has to get plumbed from a separate water intake or by using a 2 stage sea pump. If you use a separate hull pick up, the pressure alone will be plenty to feed the chiller.
Griff is offline
Elite Marine
Phantom
10
06-11-2009 04:58 PM
divenstar
10-03-2008 07:48 AM
21 scarab-1
4
07-05-2003 08:13 AM
