Teague- Parts Blow-out!!
Hey all you Boaters out there! TCM has a Ton of Misc. Parts/Pieces that are cluttering our shelves and NEED TO GO to make room for New Poducts! We will keep updating often so keep your eyes peeled. Also, if there is something you do not yet see listed, CALL US! We have it all! Ask For Parts/Sales. [email protected]
DENTED NEW 14 Qt. GEN IV BBC Oil Pan with dual kick outs. Fits most single and twin engine applications. Only 1 @ this Price! Is brand new, and when installed you will never see the defect!
1@ $500.00 Ret-$792.00
Product Spec's • Race proven windage tray prevents foaming and crankshaft splash, maintaining consistent oil pressure. • TIG welded and especially designed for marine use • Clearance for low mount starters and sea pumps • Large oil capacity. Available in 10 and 14 qt. pans and 12 qt. ”CAT” pans. • All Offshore pans notched, clears up to 4.5 inch stroke with steel rods. • High volume competition oil pick-up is welded with an added support bracket to prevent breakage. • Flexible dipstick allows easy access for universal fitment. • Clears most standard front engine mounts. (Mercruiser included) • Designed to fit BBC, Mark IV, GEN V-VI, World Products and Dart engine blocks • Reduces operating temperature and engine failures due to increased oil capacity. • Black PC coated inside and out resists staining and corrosion
TCM has a few AUTOMETER GAUGES that need to go! There is just NOT room on the shelf for them anymore! These are all we have, and are offering them to you below Cost!
WHITE GAUGES- WHITE FACE W/ SUPER WHITE RIM-
4) 3 3/8"- 7000 RPM TACH W/ HOUR METER (P/N: 200890) $94.00 EA
2) 3 3/8"- 8000 RPM TACH (P/N: 200799) $78.00 EA
1) 3 3/8"- 100 MPH, GPS SPEEDO HEAD (P/N: 200836) $97.00 EA
4) 3 3/8"- 120 MPH, GPS SPEEDO HEAD (P/N: 200837) $97.00 EA
1) 2 1/16"- OIL PSI, 0-100 PSI (P/N: 200758) $26.00 EA
1) 2 1/16"- WATER TEMP, 100-250 DEG. (P/N: 200762) $26.00 EA
2) 2 1/16"- FUEL LEVEL (P/N: 200760) $26.00 EA
2) 2 1/16"- VOLT METER, 8-18 VOLTS (P/N: 200756) $26.00 EA
5) 2 1/16"- OIL TEMP, 140-340 DEG. (P/N: 200764) $26.00 EA
1) 2 5/8"- TRIM, MERCURY (P/N: 200767) $31.00 EA
PLATINUM GAUGES- PLATINUM FACE W/ SUPER PLATINUM RIM-
1) 3 3/8"- 6000 RPM TACH (P/N: 200752-33) $77.00 EA
1) 3 3/8"- 8000 RPM TACH (P/N: 200779-33) $106.00 EA
1) 2 5/8"- TRIM, MERCURY (P/N: 200767-33) $31.00 EA
These are our entire stock of AutoMeter Gauges! When they are gone they are gone! We can order YOU New AUTOMETER Gauges, but we do not Stock them (& not at this pricing)! So act fast to get this once in a lifetime deal! If you find a better advertised price for these particular gauges, we will beat it!
To order, please contact our parts Dept! Thanks!
PH- 661.295.7000
FX- 661.295.7007
[email protected]
For all Parts check out our Website @ www.TeagueCustomMarine.com
"WE HAVE EVERYTHING BUT THE WATER"
PH- 661.295.7000
FX- 661.295.7007
[email protected]
TCM is cleaning house and has run across (3) 71 series SuperChillers that need to find new home/motor! These Chillers are brand new but have a small blemish on each of them. TCM is offering these (3) only for $1,275.00 ea! Sold Complete w/ Housing, Core, End Caps (1/2" or 3/4"), Gaskets, and Hardware (studs, nuts).
6-71 through 14-71 SuperChiller Intercooler.
Description:
If you’re looking for a cost effective method of increasing your supercharged engine’s output and improving reliability, install a SuperChiller Intercooler. Bolt-on 75 to 150 horsepower. The SuperChiller Intercooler dramatically reduces the air temperature of the intake charge, thereby increasing air density to the combustion chamber. A cooler, denser air/fuel mixture takes up less space inside each cylinder, allowing the mixture to provide an increased intake charge without the risk of detonation.
Description:
Revolution 4- RH rotaion, 14 5/8" x 21 Pitch, 4 Blade.
P/N: 48-857028-21
Prop in a New Condition! Not a Nick or a scratch!
$350.00 w/ new Solid 1" Hub (1 @ this price)
MUST MENTION THIS ADD FOR SUPER SALE PRICE!
Check online for other propellers in stock @
www.TEAGUECUSTOMMARINE.com
PH- 661.295.7000, FX- 661.295.7007
[email protected]
"WE HAVE EVERYTHING BUT THE WATER!"
P/N: 48-857028-21
[email protected]
We have sold the Blemished Chillers, but give us a call! We can make you a killer deal on any Intercooler/plumbing system!
Teague Custom Marine
[email protected]
[email protected]
MERCURY P/N: 92975A32 (Outboard Trim Pump Assembly)
Brand New! $449.97
(Must Mention add!)
TEAGUE CUSTOM MARINE
"We Have Everything But The Water!"
Brand New! $449.97
(Must Mention add!)
Billet flywheel REV ring gear w/ top mount starter, Ext. balance.
These precision CNC machine flywheels are manufactured form billet steel or 6061-T6 aluminum. Machined with dual 6-bolt mounting pattern that doubles drive-plate retention and strength for engines over 1000 horsepower. Heat-treated 168 tooth ring gear is installed in standard or reverse position based on starter location. These flywheels are available for internal or external balanced engines.
Retails @ over $370.00
10 Flywheels @ $199.97
PH-661.295.7000, FX-661.295.7007
It is going on an Alpha drive so it doesn't need to be anything spectacular.
