Ethanol
Old 10-25-2008 | 03:03 AM
Default Ethanol
We are starting to see 10% ethanol in
fuels here in Florida. Is there an additive
that you can use in this fuel for long term
storage?
myturn is offline
Old 10-25-2008 | 08:10 AM
I have used Startron's Enzyme Cleaner/preservative. It supposedly breaks down any fuel phase separation into small burnable particles.
I will warn you however, that in my big boat it helped but I still needed to install Racor fuel filters prior to the the water seps to keep from clogging the micro filter at the carbs.
Even after taking those steps, this spring I am pumping out my tanks to minimize the old fuel. This stinks because I am holding about 300 gallons right now. I am in Chicago, I would assume the fuel in Florida, would be harder to keep moisture and mold out of the tanks.
Fo my 2 cents if you are going to store for a an extended time I would empty the tanks down to 1/4 pour in a bunch of additive. At least then when you fill later the bulk of your fuel is new.
Part of the problem with ethanol is its lack of preservative. It loses 10-12% of its efficiency if it sits for more than 2 months.
Dont know if any of this helps but as a guy who lost this season due to old fuel, and after trying to burn and add, burn and add, I am still going to pay $3.00 a gallon to pump it out and then refill (575 gallons) in the spring. Best advice is to keep using the boat and keep the gas moving through the system.
the vig is offline
Old 10-25-2008 | 08:55 AM
Beak Boater's Avatar
Charter Member # 545
Originally Posted by myturn
We are starting to 10% and 20% ethanol in
storage?
Are they putting it in the fuel at Marina's also. When we we in Jax. for the Poker run, the Marina where we put the boat on the trailer, one of the guys working their saw our MD numbers and made it a point to tell us they have no ethanol in fuel at Marinas. Maybe that has changed since June.
Beak Boater is offline
Old 10-25-2008 | 10:42 AM
My marina claims they are still getting pure gasoline without ethanol, but I have seen some marinas with the 10% ethanol sticker on there pumps. Some states are required to post there pumps if there gas containes ethanol
johnny b good is offline
Old 10-25-2008 | 01:37 PM
sleek1's Avatar
I saw an ad for Stabil Marine additive. Supposedly for fuel with Ethanol. I haven't used it yet but will probably buy some in the next couple weeks.
sleek1 is offline
Old 10-26-2008 | 12:38 AM
Rebel_Heart's Avatar
It really varies by state. I boat in couple of different states, and they have completely different laws regarding ethanol in gas.
One state only has ethanol in 89 octane on the road, while another state has ethanol in all their gas except that sold for marine or aviation use.
Rebel_Heart is offline
Old 10-26-2008 | 08:48 AM
gsmith9898's Avatar
I purchased the stabil for ethanol marine use. It looks green instead of red and cost twice as much. Hope it works.
gsmith9898 is offline
Old 10-26-2008 | 02:14 PM
sleek1's Avatar
You know Marine is a nasty word. As soon as I see it on a product I translate it to mean "costs at least twice as much."
sleek1 is offline
Old 10-27-2008 | 09:00 AM
Knot 4 Me's Avatar
Regular red Sta-Bil works just fine. Been using it for 10 + years and with E10 gas.
Knot 4 Me is offline
Old 10-27-2008 | 01:18 PM
mrv8outboard's Avatar
coolrunning racing
remember that the ethanol is not only an oxygenate but octane as well. so you can treat fuel so it dose not turn to varnish but the ethanol still evaporates. this leaves you with a decision, treat the fuel and deal with ultra low octane fuel in the spring. or use it up or pump it out. otherwise the engine will run on the stuff but the risk of damage due to low octane is not worth it.
mrv8outboard is offline
