Key West GPS
Old 10-26-2008 | 01:29 PM
Xtremeracing's Avatar
Default Key West GPS
Just a heads up to all the P class racers, SBI P Class uses Garmin GPS ONLY . If you need more info and the models that are legal you can check the rule book or call Richie D.
Xtremeracing is offline
Old 10-26-2008 | 02:11 PM
thanks for the heads up! which one do you prefer?
Superheat is offline
Old 10-26-2008 | 02:32 PM
Garmin 182 they make it in color and Blk & Wht. If you look on Ebay you can find them pretty cheap. I think Al from Crazy Chicken has one he is looking to sell also .
Old 10-26-2008 | 09:31 PM
Bilgerat's Avatar
needs to be set up so as to log a point every three seconds. Does Richie check that parameter on inspections??
Bilgerat is offline
Old 10-26-2008 | 09:43 PM
Yes he will ask you if it is at inspections. If your not sure how to do it they can help you with it.
Old 10-27-2008 | 05:24 AM
purnell's Avatar
that gps is outdated, have they updated there rules to a new model. don't want to cut the dash to mount an outdated one. is frank from opa in charge of the sbi gps inspections and if so can we use the opa's gps. thanks
purnell is offline
Old 10-27-2008 | 06:00 AM
If you look in the rule book there are some other models that you csan use other then the 182 . The Garmin GPS are the ONLY one that will be allowed .
Old 10-27-2008 | 08:21 AM
MANITIE's Avatar
Frank....are the ones we used last year in K.W. still good....
MANITIE is offline
Old 10-27-2008 | 11:34 AM
You dont need to cut out the dash ,just ducktape it somewhere.
It will work. LOL
DareDevil is offline
Old 10-27-2008 | 11:45 AM
MANITIE's Avatar
Bill....don't worrie.....you will be behind us anyways.....and we won't brake out....sorry...I had to go there....
See ya in a week
MANITIE is offline
