scarab 38 kv refit
Old 10-29-2008 | 10:04 AM
Default scarab 38 kv refit
hi, folks,someone here can probably give us some advice/opinions,basically my brother has recently accquired a scarab 38 kv which needs motors and drives,what would have been fitted originally ,and or what would folks here recomend,want reliability and 60 mph would be good,any thoughts guys,thanks, we are in ireland,cheers.
seamy is offline
Old 10-29-2008 | 11:29 AM
you should ask this in the scarab section,probably get some help.
BOBCATMATHEWS is offline
Old 10-29-2008 | 11:56 AM
More than likely it originally had Merc 420's. I would definately go with bigger power.
Griff is offline
Old 10-29-2008 | 12:22 PM
Rebuilt the 420 if they are 420 , not 400's and if so , put a samll blower on them. The 420 had all real good parts in them.
With a small blower and diffrent pistons to mach the blower you should get easy 550-600 HP.
DareDevil is offline
Old 10-29-2008 | 08:17 PM
Define "small blower"... something like a 250? And what types of speeds could he expect with 550-600 HP?
Shallow Minded is offline
Old 10-30-2008 | 10:24 AM
BAJA WILL's Avatar
Registered User
OK, you aquired a big boat that needs power and drives. Well guessing by the age your going to need so much more, rigging, wiring, motor mounts, cables, K-Planes??, Trim pumps, OMG the list goes on. From some one who does this for a living, find a totaled boat you can strip LIKE THIS ONE.
http://cgi.ebay.com/ebaymotors/Boats...=p4506.c0.m245
Not only will it have everything you need and more, you will know how it goes on because you will have taken it off.
WILL
BAJA WILL is offline
Old 10-30-2008 | 01:40 PM
guys the boat already has everthing/trim pumps cables looms and wiring really need two motors and drives, i can post a few pics of the boat as weve got it so far,if i ever figure out how,thanks guys.
seamy is offline
Old 10-30-2008 | 02:54 PM
Biggus's Avatar
Most 38KV's were rigged with TRS drives, Konrad Marine's 540 sterndrive system is a bolt on package for the long discontinued Merc TRS.
Check it out at www.konradmarine.com
or send me an email direct at [email protected] and I'll send the brochure and pricing.
Kurt
Biggus is offline
Old 10-30-2008 | 04:47 PM
satisfactionII's Avatar
that Formula would be the perfect parts boat. You could get that boat cheaper than buying the rest of stuff needed for the KV. You have to be real careful, choosy, and do a lot of work yourself or you will get in extremely deep on the Scarab project.
satisfactionII is offline
Old 10-30-2008 | 06:47 PM
yes guys i dont doubt this is a good deal,but the fact that we are in ireland/uk,shipping that lot back simply for this project i believe,the costs involved would be crazy,surely there must be someone private or indeed a reputable dealer in the states that will work a deal with us and sort shipping back to ireland at a sensible price,any ideas,cheers.
seamy is offline
