Replacement for marine plywood?
I have to replace the piece of 1/2" plywood that was over one of my fuel tanks. It's ~8' x 3'. Is there anything better out there then marine plywood in this high tech world of ours?
There are a lot of different types of Marine Plywood as well. When I redid my transom we did it in Marine Mahogony Plywood. That way it will not soke up water like the otheres may. Good luck.
Jon
Jon
I used deckolight on my floor and it is expensive, about $230.00 a 4x8 sheet.It's a baltser core and glass skin on both sides.You must seal the edges. You can buy it at a fiberglass supplier.
I just went through the same deal and I ended up using marine plywood. The starboard looks great but it's expensive and not available locally. Do not use "non marine" plywood as it will not have waterproof glue and it WILL delaminate. Epoxy coating can be a good option if you are ABSOLUTELY sure that water will never enter the structure through a ding, scratch, or screw hole. If it does the epoxy will not let the moisture escape and rot will begin even sooner.
On my engine cover I chose to use mahogany marine plywood with fiberglass on one side (the side exposed to the engine) and leave the other side unfinshed (the side with upholstery) to allow moisture to escape.
zimm17
3
08-24-2006 12:01 PM
AGGRAVATION28
Detailing, Painting, & Fiberglass
13
11-04-2005 09:05 AM
