Alm. Blocks
For you experienced engine guys out there ... What would be the pro's and con's of using a all aluminun motor in fresh water. Except for the price. Would they have as much durrability as iron blocks in a N/A 598 or 632. Would the weight saveings be notable in a twin 40 ft V
This came up awhile back, the general consensus was that if it was a good idea, all of the major engine builders would be doing it and they don't. BUT it was also mentioned that Raylar recently introduced and aluminum block motor, something worth taking into consideration. Talk to mrhorsepower(Dean Gellner), he built some aluminum block motors for a flat deck I was looking at, but we passed on the boat so I didn't want to waste his time talking to him about the motors.
i think it depends more on the weight balance of the boat and the rigging. when i win the powerball i am going to build something with aluminum block power and closed loop fresh water cooling. either a 800ci bbc single engine 28-30 ft or a twin staggered big small blocks...
i pipe dream a lot....
Seems like the idling issue would be erelevent . How long does it take to warm a moter two or three times a day at 80 or 90 degree outside temp ?Not like we run these things in snow and ice! Everyone worryies about top end speed with little fuel skinny wife or girlfriend no gear no cooler to get 1 or 2 mph. Seems like all alm motor at half the weight would save like 600- 700 pounds on a twin eng application right on the tail end compared to all stock iron stuff . Getting the tail end up is all the talk on props and hull design. ANY THOUGHTS ?
MR
