Props? Repowered 42 Lightning >
Old 11-08-2008 | 09:47 AM
wahweap's Avatar
Default Props? Repowered 42 Lightning
Just finishing putting Whipples on the 525's of my 03 42 Fountain Lightning. Still have the stock XR outdrives. With the 525s, 1.5 ratio, 30 pitch 4 blade B1s, I could only reach 78 mph at Lake Powell (3600 ft) turning 5100 rpm. My slip calculations are in the 25 % range. Now with the 700+ HP, where do I go with the prop set-up? Any direction/suggestion is greatly appreciated.
wahweap is offline
Old 11-08-2008 | 10:06 PM
1.36 gears would be a good start
flat rate is offline
Old 11-09-2008 | 06:26 AM
Get some 5 blades from BBlades in the mid 30's for testing.
Carder
Carder is offline
Old 11-09-2008 | 09:00 AM
wahweap's Avatar
oops, they are 1.36--had 1.5 on the 27 fever ( you know, 120 -121, whatever it takes!). You suggest BBlades will be most helpful? Sounds terrific---I'll call and see if I can demo something; I'm thinking 30 pitch maximus 5 blade, then I'll work my way up from there. Thanks !
wahweap is offline
Old 11-09-2008 | 10:23 AM
I added 100 hp per engine last year and went from 28p 4 blades to 31p 5 blades (equivalent to 32p 4 blades)
If you have added nearly 200HP, your going to need a larger change, plus Brett probably has outfitted a similar boat, and knows where to start... It's a process, but it sure is fun!
Carder
Carder is offline
Old 11-10-2008 | 06:30 AM
wahweap's Avatar
Thanks for the help! I'll talk to Brett.
wahweap is offline
JBergstrom777
Fountain
11
01-04-2008 06:39 PM
fcalligaro
Skater
15
08-01-2007 08:17 AM
DRIVEN1
Fountain
15
09-01-2006 08:28 AM
StarLoone
Fountain
36
10-06-2005 08:14 AM
StarLoone
Fountain
13
01-30-2005 10:06 PM
